Post new topic Reply to topic  [ 290 posts ] Go to page Previous  1 ... 8, 9, 10, 11, 12
Casey's V8 5spd:Cort's, no, Casey's, no, Cort's, no Keith's!
 Post subject: Re: Casey's V8 5spd:Cort's, no, Casey's, no, Cort's, no Keit
PostPosted: Fri Jul 28, 2017 7:40 pm
CaifanSC wrote:
shiny parts! What are you doing for your steering hoses? Custom made?
I recently just amputated my legs in exchange for nos hoses through Audi
Mike
'91 V8Q Pearl w/5 Speed
'90 CQ Alpine White / AAN
'90 CQ Crystal Silver
'91 90Q Tornado Red (RIP)
'86 Monte Carlo SS
PostPosted: Fri Jul 28, 2017 7:42 pm
They're still available thorugh audi????? I thought they were NLA
91 Audi V8 Quattro Black/Black OEM 5speed (Later to be Red/black 4.2L 6speed)
03 Audi S8 Avus grey/Oxblood red (later to be 6speed)
91 BMW 850i - Red 6speed
94 BMW 850Csi - Red 6speed
94 & 95 Ford Thunderbird Supercharged 5 speed
92 Mustang convertible 5speed
PostPosted: Fri Jul 28, 2017 8:16 pm
I was able to source them through a few dealers down south , one in Florida and one in Georgia
Mike
'86 Monte Carlo SS
PostPosted: Mon Jul 31, 2017 1:21 pm
Old next to new
Shiny parts
Mike
'86 Monte Carlo SS
PostPosted: Fri Aug 11, 2017 4:59 am
Power steering system is solid . Week after replacement and completely dry, needless to say I am beyond excited for that. Next is to tackle the weepy valve cover baskets and see what's the source of my next leak to repair. After degreasing everything last time it seems to be the rear main slowly weeping as well. I'll find out more this weekend when I can check it out.
Mike
'86 Monte Carlo SS
PostPosted: Fri Aug 11, 2017 8:47 am
Good update!
was steering rack part of your overhaul? Where did you end up getting the reman pump?
PostPosted: Wed Aug 30, 2017 4:41 pm
More parts for the upcoming holiday weekend fun
Mike
'86 Monte Carlo SS
PostPosted: Fri Sep 01, 2017 10:00 am
PAAAAAAAAAAAAAARTS!
What's the gasket for all the way to the right? Oil pan? Which plug wires did you go with? And what's that little Bosch box for :)?
PostPosted: Fri Sep 01, 2017 11:01 am
Magnecor wires, have them for my coupe figured I'd do it for this as well. Little Bosch box is pressure sender , distributor o rings up top left and yes both upper and lower oil pan gaskets though I probably won't be doing that til my next oil change is due. I'm slowly gathering parts that could need replacement/ adding small things to get that minimum amount for free shipping ;)
Mike
'86 Monte Carlo SS
PostPosted: Sat Sep 02, 2017 7:15 pm
Pleased to see how clean the head looks from under the VC. Everything went much smoother than expected. New plugs , wires , FPR , Cap / rotors , VC gasket just for today. Next weekend I'll get the AC functioning, just awaiting the compressor to arrive
Full speed ahead with this, want to enjoy it as much as I can before I put her away for the winter
Mike
'86 Monte Carlo SS
PostPosted: Tue Sep 05, 2017 9:40 am
So in the midst of all this I did a thing and picked this up today
Mike
'86 Monte Carlo SS
PostPosted: Tue Sep 05, 2017 6:34 pm
awesome progress.
is the coupe also pearl?
PostPosted: Mon Sep 18, 2017 3:33 pm
CaifanSC wrote:
awesome progress.
The coupe is alpine white, so it's slightly different than the pearl.
Progress on the v8 continues . Replaced the shot ac compressor clutch, was really really botched. Very tedious process , had to use air chisel to split the nut off then had to re thread the shaft for the clutch, but after all it is complete , together and operating. Have to replace an o ring on the front line to the condenser and I'll be able to have a/c just in time for winter
Mike
'86 Monte Carlo SS
PostPosted: Fri Nov 06, 2020 3:57 pm
Resurrection of this thread. I’ve been without the car for quite some time (almost 2 years) due to it being backed into and the front end crushed in. Fast forward to now, Lo and behold, it’s back, buttoned up and fresh new paint all around. Can’t wait to enjoy it before full winter sets in.
Mike
'86 Monte Carlo SS
PostPosted: Sun Nov 08, 2020 3:28 pm
Brought her home today, trying to work out some gremlins of course. I haven't driven the car in close to two years so I figured there would be problems.
Lights are a sure fix. The headlight wiring was messed up upon re assembly, and I'm blindly putting wires to pins in hopes to narrow what goes where.
Somehow in the mix of messing with the headlight wiring, I lost half the driver side tails, not sure if it was coincidental, or if the wiring is linked? ( I dont have a bentley for the v8 so no wiring diagrams.) Turn signal works on driver side but no rear markers.
Figure out a crank no start issue when the car is hot.. (Crank or cam position sensor, or perhaps a coolant temp sensor?)
Could use new plugs for sure, have to find what the oem were as well as gapping.
Mike
'86 Monte Carlo SS
Users browsing this forum: Google [Bot] and 1 guest
  |  It is currently Thu Apr 22, 2021 3:54 am
