Author |
Message |
dean16v
Post subject: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Fri Feb 04, 2011 11:05 am |
mach 2 with my hair on fire |
Joined: Tue Apr 29, 2008 9:23 am Posts: 2057 Location: Hudson Valley, NY
As some may or may not know, I have been pushing along with a Coupe Quattro project that I have coined "Project: Mayhem". For quite some time now I have been working on this thing and the time has come for me to start the project thread, of course with lots of pictures, but please bare with me, as for I have done a lot, taken quite a few pictures (that will be uploaded at different times), and yeah... I am always busy.
As a teaser, here is the plan/spec sheet (updated 11.30.2019); Exterior: • Repainted Audi Paint code ??? • Audi B4 chassis (1993-95) front end conversion; radiator support, hood, grille, etc. • Audi S2 front bumper, turn signals, & projector fog lights. • Audi S2 rear bumper with Julet Motor Co. custom fabricated mounts to work with factory holes. • Rare OEM Audi RS2 Door mirrors with factory mounting brackets. • OEM Audi RS2 headlights with 4300k HID. • Audi Coupe/S2 European rear center taillight/license plate surround. • 91' Audi Coupe Quattro Roof section with rare, 91' specific, glass sunroof. • Front & rear Audi "S2" emblems (remanufactured - S2forum). • Shaved/filled jack points at lower rocker panel. • European license plates to match NYS issued vanity plate ("M3HYAM") • Custom headlight harness for RS2 headlights. • Custom front lower valance based on Seat Cupra R and Audi 80 Competition (have to see how it all fits first). • Customized blacked out front grille, grille trim, rings, and rear hatch rings/emblems. • Saved & smoothed engine bay w/ wire tuck, including; all wire tie studs, various brackets, coolant reservoir, ABS motor, battery tray, body panel seams, etc. • Custom louvered hood, resembling infamous Audi Sport Quattro. Engine/Turbo/etc.: • AAN 5 cylinder (2.2L stock), machined .020 oversize. • Eurospec “stroker” crankshaft, 98.5mm stroke (2.6L with oversize pistons). • JE pistons, oversize. • JE piston rings. • SCAT forged H-beam connecting rods. • 034 Motorsport coated crankshaft bearings. • 034 Motorsport density line motor mounts, modified with welded center. • ARP hardware (head studs, main bearing studs, rod hardware). • 2.3L 7A cylinder head w/ machined water ports for turbo application, ported & polished, and gasket matched intake/exhaust ports. • 7A intake and exhaust camshafts (2.3L NA motor, better boost curve). • Wagner Tuning high flow RS2 exhaust manifold, ceramic coated with new hardware. • Rare "powered by Porsche" OEM Audi RS2 intake manifold. • Audi UrS4 valve cover with “turbo” coil cover. • Audi Coupe Quattro engine brackets. • Audi Coupe Quattro 2-piece oilpan w/ AAN windage tray and modified sump wing for turbo oil drain. • Garrett/Forced Performance 3582R turbo w/ anti-surge compressor inlet, fabricated ½” spacer, extened hardware to clear factory style manifold. • Custom Carbon Fiber air intake and intake piping, to resemble Audi factory rally/race cars. • Factory Audi S2 ABY engine code aluminum boost piping. • Audi Coupe Quattro power steering pump, modified for ABS delete. • Audi S2 front mount intercooler cross-over pipe/code support. • Wagner Tuning S2/RS2 front mount intercooler. • TiAL 44mm wastegate w/ 034 Motorsport "drop in" riser only. • Custom stainless hardline and braided stainless hose turbo oil and water line set. • VEMS stand alone engine management. • Fabricated engine management wiring harness. • Siemens 93lb low impedence, fuel injectors. • 034 Motorsport aluminum fuel rail & mounting/retainers set. • Aeromotive fuel pressure regulator w/ 034 Motorsport fuel pressure gauge and custom mounting bracket. • -8AN fuel lines and fittings, black cloth. • Extra long spark plug wires (hide for engine bay shave). • Rebuilt alternator, powdercoated. • UrS6 serpentine belt cover (Kind of rare and courtesy of Shokan Audi, 1-800-ALL-AUDI). • AAN serpentine belt setup to replace v-belts, including; crank, power steering, and alternator pulleys. • 034 Motorsport/Ron Davis HD aluminum radiator w/ full tabs. • Carbon fiber radiator fan shroud and diversion panels, to resemble Audi factory ralley/race cars.. • Derale high flow, low profile radiator fan. • Custom Julet Motor Co. & Fabrication 3" turbo downpipe thermo wrapped and sprayed • Fabricated 3" stainless steel exhaust w/ V-Band flanges, electric cutout, new Dynomax VT muffler w/ valve, & 6" wide slash cut oval tailpipe. • Audi 1.8t intake air temperature sensor. • Audi 2.0L turbo cool on plug coils. • Mocal 16-row oil cooler w/ custom lines, mounted in place of auxiliary radiator (grille). • Forge hybrid diverter valve (as of now, we'll see if it fits and it kind of doesn't). • Custom aluminum charge/turbo outlet piping with in-line diverter/blow-off valve boost sensing side (newer theory). Transmission/Brakes/Drive Train: • 5-speed 01E manual transmission swap from a 95.5' UrS6 w/ a rare wide first gear, Audi 4000Q 100mm axle cups (allowing for use of Coupe Quattro axles), rare OE Audi RS2 shift linkage w/ radial bearing mod., and OE Audi RS2 transmission brackets. • Audi 4000Q steel driveshaft, rebuilt. • 034 Motorsport density line transmission mounts. • 5x112 lug conversion, using Audi S2 Coupe front and rear spindles and lug stud conversion. • 034 Motorsport single mass, steel flywheel w/ 0-60 ECU pickup. • Southbend DXD clutch, stage 3. • Amsoil synthetic gear oil, including; gearbox, front, and rear differentials. • Porsche 996 front brake calipers, powdercoated red with “Porsche” decal. • Audi RS2 brake caliper brackets with factory hardware. • European Audi A8L front brake rotors, vented - turned down to 307mm • Audi UrS6 rear brake calipers rebuilt. • 2001 Audi S8 rear caliper carriers, powdercoated red with 3mm spacer & extended hardware. • B7 Audi S4 rear brake rotors, diameter machined to 10.125 inches, vented. • Braided stainless steel brake houses, front & rear. • ABS delete, using Audi 80Q brake booster, spacer, and master cylinder. • 034 Motorsport "solid" aluminum front & rear sub-frame mounts. • 034 Motorsport Delrin rear differential mount. Wheels/Suspension/Stance: • BBS E50; 17x8.5" wheels staggered fitment (RARE), with 5x112 spare donut. • Tires (as of now) Goodyear Eagle GTA; 205, 40 R17. • 15mm hub centric wheel adapters rear. • 25mm hub centric wheel adapters front. • KW Suspension “Variant 3” coil over suspension. • 034 Motorsport density line strut mounts, front & rear. • 034 Motorsport density line sway bar bushings, front & rear. • 1995 Audi 90 Quattro upper strut bar with factory weld-in mounts, shaved. • 034 Motorsport Denrin control arm bushings, front and rear. • Cast front control arms (91' year models & newer only), powdercoated. • 91' Audi Coupe rear sub-frame with factory sway bar tabs, powdercoated. • Audi 4000Q rear sway bar (factory front on a 4KQ) and 'shorty' links. Interior/Convenience/ICE: • Audi S2 steering wheel, with “S2” badge, reupholstered with exposed Audi Sport style stitching in perforated leather by Craft Customs, TX. • Stack Ltd. white face speedometer cluster. • Recaro Profi XL passenger seats (larger). • Fabricated power seat mounts with Recaro seat brackets. • Reupholstered interior; black leather w/ grey Alcantara inserts and Passat CC style stitching on front seats (w/ “RECARO” embroidery), rear seat (upper and lower section), door cards, rear cards (Love's Trim Shop, Hampton, GA). • Gray Alcantara shift boot. • Gray Alcantara headliner. • RARE Quaife delrin shift knob. • Schroth 5 point racing harnesses, red. • Fabricated weld in 8-point roll bar. • Alpine media head unit w/ iPod cable. • MB Quart component speakers, front and rear. • MB Quart 8" subwoofer and amplifier in custom Jackson Autowerks enclosure. • Justmatz floor mats, custom black carpet, grey piping, and red 'quattro' embroidery. • Manual climate control swap (88' Audi 80Q) to eliminate vacuum & maintain AC (I'm driving this thing!). • Innovative Motorsport wide band display w/ turbo timer mounted in place of heated seat switches. • Stack Ltd. (white face) auxiliary gauges in factory location with modified bracket including; oil pressure, oil temp., and voltage • Stack Ltd. (white face) cluster display in custom carbon fibre cluster. • Red Strapping interior door pull (Porsche GT3RS inspired) or factory chrome powdercoated black. • Carbon Designs replica Audi RS2 style carbon fiber trims, including; doors, dash, and rear quarter panels. • OEM Late 3B S2 Coupe Black interior A, B, C trims, lights, grab handles.
_________________ BUY MY COUPE QUATTRO SPARES!!! Julet Speed & Marine Transport; Towing & Logistics - Hudson Valley, NY Email>[email protected] 90' CQ - "Project: Mayhem" / 00' Jetta TDI - "Peach" / 09' Tacoma DCSB - "Fish Taco" / & All Those Loved and Passed On
Top |
dean16v
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Fri Feb 04, 2011 11:23 am |
Prologue (Part No.1):Over the Winter of 2007-08, while my friend Aaron was converting his Lago Blue Coupe (seen often at shows with the Borbet Type A's), I had desided, given I always wanted a Coupe, that I was going to start my own and of course build it bigger and badder! Searching the classifieds and Craigslist, I finally chose to buy an unmolested, running, driving, Tornado Red, 1990 CQ from my friend Brett whom bought the car from Emre aka 'Yummyjager' with the same intentions, but who wasn't ready for a project. So, in ~April 2008 I was the proud new owner, trailered her home from Kingston, New York and started to plan out my route of action. Given my financial situation and history on how I have been able to afford those past projects, I thought it best to store the car, gather parts, and prepare for the long Winter months. I then bought an AAN from my good friend Eric aka 'Mange3586' (he had bought Emre's S4 for the 6-speed RS2 transmission and was recoving the cost, so I bought the motor, head, and a few accessories, but no ECU harness, turbo, or manifold), I also acquired an 01E 5-speed for towing a friend home, and gathered what I could in the way of parts and information. In July, following my grandfather asking me to move the car from our barn for a few days while he got lumber out, a freak and severe thunderstorm rolled through. Not showing the car with leaves, breaking a branch, but uprooting a 12inch diameter Locus which then landed across the roof.   Fired up the ol' John Deere 80EV Chainsaw, romantically known as 'the butter knife' (my grandfather cleared many of building lots with it prior to passing it down), sawed up and off as much of the tree as I could, leaving a section small enough that I could lift (I am always stuck working alone), I tripped on the cut wood, put the 'just shut off' ol' brakeless chainsaw into my leg! Slowed me down for about an hour or so, since the damage squirted blood more than leaked it (and in the picture I had wiped well and slowed the bleeding down with pressure), but was able to walk back to the house, visit a few friends that drive the town's ambulance, borrow a suture kit, stitch up the wound, and get back to the back barn, and take a closer look at the coupe's roof.   Fact is, tree wasn't even mine, on my property but given the fact I tried to be nice to the neighbor, I opted to not go the nasty route and to ask. From asking them to look into their insurance, getting a body shop estimate of $5000 if I bought the roof section, and then getting turned down, another plan had to be devised. At this point, most would have definitely waved the white flag, given up, and parted the car, but I am far too stubborn for that. You will all eventually come to realize the project name is quite suited. I actually started out with the car, pre-events, as it "Project FeO2" (Ferrous Oxide or Fool's Gold), then "Project Hard Luck", but...
Top |
dean16v
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Fri Feb 04, 2011 11:33 am |
Prologue (Part No.2):I chose to find another shell. Through the same course of action, I was able to work a pretty sweet deal on a non-running (failed attempt to complete a timing belt), 1991 Pearlesant White CQ in Delaware. So, in ~November 2008 I saddled up the truck and trailer once again, called a close friend and fellow tow truck operator, "Camel Towing Jay", pulled an all nighter, and drove down to Delaware and back. Sure I became the proud new owner of a CQ filled with parts and cartons of cheap cigarettes we had bought, but this trip alone has a whole other hilarious story packed with ~clap~ "so this is how it's going to be" negociations, directions that included going "sKraight", hitch hiking hippies, and making it home in 4 hours, LOL. In February 2009, after the smoke of the holidays and January birthdays had cleared, tear down into the pearl coupe, welding all the engine bay seams (for a shaved and smoothed bay. Weld, grind, weld, grind...), and looking things over only brought disappointment. One night the Toy Maker happened to stop over, look things I had been doing over, and discovered that this car had a pretty tweaked frame rail. SH1T! (*You can just about see the bulge and dent in the frame rails, near the motor mount brackets, in the pictures below... even around the grinding marks)   So, the story starts off on a simple question... Quit while you are ahead, put the roof of the red car onto the white car, or put the front frame rail and inner fenders from the red car into the white car? A night at the bar, determined not to quit, having a friend ("The Toy Maker") who's father had owned a body shop and just graduated from Wyotech, and having the title (in hand) for the red car, the decision was easy...
Top |
aantoxa
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Sun Feb 27, 2011 2:21 pm |
Redline? |
Joined: Tue Mar 11, 2008 12:18 pm Posts: 138 Location: Bay Area, CA
Top |
amd is the best
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Sun Feb 27, 2011 4:46 pm |
Joined: Thu Sep 17, 2009 8:35 am Posts: 1254 Location: Schenectady, NY
This thing = titz. I've had the pleasure of seeing some progress in person!
_________________ Nick '13 Golf R - APR Stage 2+ '91 200 20v - whoa '91 200 20v Avant - stock
Top |
fafwa45
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Sun Feb 27, 2011 7:15 pm |
kickin' tires'n lightin fires |
Joined: Thu Feb 11, 2010 11:58 pm Posts: 685 Location: Vancouver,Wa
Any updates?
_________________ 1990 CQ 190k silver/black
Top |
Wheeljack
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Sun Feb 27, 2011 10:03 pm |
Joined: Sun Jul 01, 2007 7:35 pm Posts: 1229 Location: Holladay, UT
Quote: • Repainted Audi Titangrau, paint code: LY7P (Titangrau Silver Poly, aka: Titan gray).
• Custom Carbon Kevlar air intake and intake piping, to resemble Audi factory ralley/race cars.
• Carbon Kevlar radiator fan shroud and diversion panels, to resemble Audi factory ralley/race cars. I guess I missed this first time around... Awesome choice on paint. I'd love to see it in titan gray...also interested in the carbon/kevlar pieces you mention... Can't wait to see more pics...That is an amazing spec list!!!
_________________ The Projects: eS2 Coupe /// ur quattro /// urS4 /// Diesel Vanagon
Top |
a_CQ
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Sun Feb 27, 2011 10:06 pm |
I post, therefore I am |
Joined: Thu Oct 12, 2006 7:15 am Posts: 6092 Location: Chicago
Good stuff, Jack! That motor looks nice..
_________________ Peter
Top |
ShavedQuattro
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Sun Feb 27, 2011 10:10 pm |
Joined: Sat Dec 06, 2003 4:03 pm Posts: 6611 Location: Provo, UTAH
Is the stroker bottom end already assembled? I hope that crank is going in a tall deck..
_________________ Hank 81 URQ 20vt 612whp/527wtq
Top |
dean16v
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Sun Feb 27, 2011 10:40 pm |
So, the project was about to really, really start... I had the 1991' Pearl Coupe already in the barn, the engine bay was stripped down (don' let anyone tell you that removing the engine harness from the firewall is easy!), and I wasted plenty of time wasted in learning how 'shave the bay'.  It was time to fire up the Tornado 90', drive her up to the barn, and get them both fully stripped and ready for body work.  So, that weekend I climbed up to the high dive and dove in head first. The thing fired right up too! Drove her up to the barn, pulled it into another bay, and started with the standard fluid drain, motor pull (to have some 7A parts to sell), and followed that with an interior strip on both of the cars, as not to damage as much with the roof sectioning.        (Yes, that's a cast on my hand. Around the same time, my father had closed a garage door on the B5 S4, it dragged down the trunk and rear bumper, and yeah... didn't apologize and blamed me for leaving the door open, all I needed was a 'sorry'. It was his face or the side of the barn, pole barn won, especially with the 8"x8" stud behind the board and batten)
Top |
Frank the quattro tank
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Tue Mar 01, 2011 12:16 am |
Joined: Sat May 17, 2008 10:52 pm Posts: 2070 Location: Quincy, Illionis
Nice! Looking awesome!
_________________ 1988 90 quattro Clearcoat Black 1990 90 quattro 20v Tornado Red- Crushed before she should have been :( 1978 Yamaha XS500
Top |
Hybrid_Hatch
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Tue Mar 01, 2011 8:27 am |
Joined: Sun Oct 09, 2005 6:16 pm Posts: 5695 Location: Oregon/Utah
dean16v wrote: • Black painted interior lights, grab handles, and panels (factory only offered beige). Only offered beige in the USA.
_________________ //Dave
Top |
mxnhid
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Tue Mar 01, 2011 10:48 am |
I sprinkle rubber on my Cherios |
Joined: Wed Dec 03, 2008 9:08 pm Posts: 422 Location: Atlanta
I would like to know where you got the Siemens injectors from. 80# is a nice injector size. Ebay? Can you provide a link? Nice project, it will be one of the nicest coupes out there for sure. Stop punching walls! All that does is hold us up on seeing the rest of your project
_________________ 1991 Lago Blue Avant under construction
Top |
dean16v
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Tue Mar 01, 2011 2:39 pm |
pitten wrote: Hi Jack, bummer to hear about the frame tweakage! Hope your current plan works out! Cartons of cheap cigarettes? I guess we never dug deep enough to find those..  No, no, no... we stopped at a gas station on the way home and pretty much filled the car. It was definitely an eventful ride back to New York; Meeting you all, negociations, stopping for cigarettes, trying to find a Checkers in the heart of the ghetto in Wilmington (got directions from a chick that was so ghetto'd out that she looked like a dude and said 'baby you's gots to go sKraight'), hitch hikers that needed a ride in Jersey, and blowing home in less than 5 hours!
Top |
dean16v
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Tue Mar 01, 2011 3:11 pm |
So, now both the cars were stripped, or at least for the most part. I had the complete interior, glass, and whole shooting match pulled from the tornado Coupe, discovering that this was no 'hammer-out' dent in my roof.  On the pearl Coupe I had the headliner, grab handles, trims, sunroof, and related pulled, but left the carpet and seats since this chassis wasn't going to be seeing the welding that the other was.  My next step, as directed from my friend the 'Toy Maker' and body work tutor, was to remove the seam sealer, paint, primer, and expose all of the factory welds (on both cars) so we could see how the Krauts glued these things together, then mark out where we planned to cut. They did a pretty damn good job building these things, if you ask me, there was a gagilion squeeze type resistance spot welds, panel adhesive on the roof stiffener bars, and brazed the corners of the front and rear windshield areas.    Of course there was some fun stuff too. He and I worked a few nights, and let me tell you... one, I have never seen a car cut apart so fast (neatly) and two, boy did I get well aquainted with the Blair/Spot-weld drill bit, but we are NOT best friends! It was necessary though, with my attention to detail, being a perfectionist, and wanting the car done correctly, so after making a pearl white speedster Coupe, I drilled my little heart out on both the tornado Coupe and the roof section. I had to think before drilling too (hard after a long day at the work and in the cold as barn), managing to only remove the skin and rear support from the tornado Coupe and vise versa on a the roof section.
Top |
amd is the best
Post subject: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Wed Mar 02, 2011 8:12 am |
mxnhid wrote: I would like to know where you got the Siemens injectors from. 80# is a nice injector size. Ebay? Can you provide a link? Nice project, it will be one of the nicest coupes out there for sure. Stop punching walls! All that does is hold us up on seeing the rest of your project  Www.pagparts.com
Top |
dean16v
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Wed Mar 02, 2011 10:04 pm |
After addressing the bent parts, drilling all the spot welds, and getting a pure roof skin/section with the necessary cross members, I was able to Cleko the new skin to the car (understand that I never intended on any of this and along with Cleko pins and pliers, have more autobody specific tools than I ever wanted to add to the inventory). So, pre-welding on the new skin I had an opportunity to address some other areas requiring attention and repair. These areas included a dime sized hole in the frame rail where the battery vent tube had spewed acid into an area of grease, dirt, and yuck where is was able to do some damage (Look... See the hole? Yeah, right through!). So, with the pearl Coupe a blaintant parts car and body panel donor, I went at it with the sawzall and got myself a nice section of rail, but would be using a 10th of it.  Another area was the front to the frame/radiator support that was a little bit bashed and twisted in a fender bender, didn't much affect anything, but why not fix it and make it look nice, nice? Once again, with the pearl Coupe a blaintant parts car and body panel donor, I went in search of what I needed, irony is the color... should have been a hint from the start that there were some body issues on the car.
Top |
Hanicus
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Thu Mar 03, 2011 3:03 pm |
Joined: Sat Oct 22, 2005 8:23 pm Posts: 1745 Location: Pittsburgh
Holy chop cut rebuild! Might as well chop it and shorten it while you're at it
_________________ 2003 BMW 330i ZHP 6spd [-SOLD] 2006 Volvo V50 T5 AWD 6spd [DD] 1990 CQ [S2 Project] 1996 Passat TDI -SOLD 1990 CQ -SOLD 1995 Audi S6 -PARTED 1993 90 quattro sport [gf's car]-SOLD 1989 80 quattro [DD/first car]-SOLD 1984 4ktq project -SOLD
http://www.coroflot.com/hansnielsen
Top |
dean16v
Post subject: Re: Dean's "Project: Mayhem" - Coupe Quattro 20Vt Posted: Thu Mar 03, 2011 3:10 pm |
Spike_Rally wrote: Holy chop cut rebuild! Might as well chop it and shorten it while you're at it  Well past that at this point, but the thought did pass through my mind prior to realizing that making a driveshaft would be a b1tch.
Top |
