Author |
Message |
Fbatwork
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Tue Aug 28, 2018 6:14 pm |
I sprinkle rubber on my Cherios |
Looks good, should definitely see an improvement.
_________________ 2010 Dodge Ram 4X4 1500 2003 Audi RS6 1991 Audi Quattro Coupe eS2
Top |
CoupeMaster
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Wed Aug 29, 2018 7:00 am |
DE80q wrote: Well, I can finally let this one out the bag. About a month ago, I had a lengthy discussion with Tim about making a higher flowing, factory placement manifold. Over the past couple weeks, I've been getting some pretty neat pictures of his progress. It almost done now, just one last tube to make for the wastegate. Figure at this point, I can start sharing some of these pics. Tell me what you guys think. I was talking to Tim the other day and he showed me these pics. that def look the business I didnt know it was yours. def more flow to say the least
_________________ -2013 Audi S4 6Speed EveryDay Fun -2012 Audi S5 -90 CQ (AAN Built 01E in progress) --2012 RAM 1500 black express(Audi parts hauler)
https://www.motorgeek.com/viewtopic.php?f=6&t=204234" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; South Bend IN
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Wed Aug 29, 2018 8:11 pm |
I post, therefore I am |
CoupeMaster wrote: DE80q wrote: Well, I can finally let this one out the bag. About a month ago, I had a lengthy discussion with Tim about making a higher flowing, factory placement manifold. Over the past couple weeks, I've been getting some pretty neat pictures of his progress. It almost done now, just one last tube to make for the wastegate. Figure at this point, I can start sharing some of these pics. Tell me what you guys think. I was talking to Tim the other day and he showed me these pics. that def look the business I didnt know it was yours. def more flow to say the least Well, other than Jarid, who else is being dumb enough to push these old tractor engines...
_________________ "If you can't find one, make one"
Dallastown, PA 1991 Audi 80 quattro (10vt project) 1991 Audi Coupe Quattro (my first 20v) 2007 Mitsubishi Raider(Dakota in disguise) 2019 Chevy Cruse Hatchback RS (wife's new ride)
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Mon Oct 22, 2018 8:12 pm |
Today's mini project seemed to go well. I was getting very little air from the defroster vent, so I pulled the DS knee board to investigate. Turns out one of my cables had detached itself at the controls and was just moving around. I held it in place, and was able to get everything to move as it should.
Now on to the "seemed" part. Drove the car to work tonight, and had zero heat! I honestly think it was cooker inside the car than outside. Now I need to investigate this. Not sure what changed on that front between Friday and tonight...
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Tue Oct 23, 2018 8:13 am |
It's fixed for now...
As some have pointed out, I did have some air in the system. I filled the tank, and ran it without the cap for a while. Watched the tank level drop significantly... So filled back up and hasn't moved. There is also the issue of the cables no longer being attached to the box. I don't mean where the eyes wrap around the pegs on the arms, but the clips that hold the outer plastic to the heater box. So for now, they are zip tied to the floor vent to keep them from moving. It actually worked extremely well! I can cylce through the different vent positions and adjust the heat level! I'll have to pull the dash out at a later date and fix it correctly.
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Thu Feb 20, 2020 5:53 am |
So it has been a while. Nothing really happening with the bandit this winter, as I have been slowly working in the CQ. Last night we were kind of slow, so I decided now was time to do something for it! I have a rather large 58mm turbo with a #8 hot side. I also have an Audi K26 #6 housing laying around. I wondered if I could make the big turbo fit into the smaller housing. Seeing as lots of people have them machined for HX35s, I figured I would give it a go. I made a chucking fixture and went to town. I made all the dimensions the same as the #8 housing. I had to take about .300" out of everything!  Unfortunately, I found out that this particular housing is cracked...  It will have to do for now, it's all I have. As you can see, some of the volute has.been machined away. The #8 housing has been ground to make it have a full circle again. Is this necessary? Might be a dumb question, but I don't know. Pic shows ground area  The final result...  While it does appear to fit, it in fact does not. It appears I have cut the wrong radius in the back, so I need to put it back up and address that. It doesn't seem to be hitting by much, but hitting is still hitting. I'll update when I can.
Top |
elaw
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Thu May 07, 2020 7:45 am |
mach 2 with my hair on fire |
Joined: Thu Oct 22, 2009 10:59 am Posts: 2486 Location: Sitting in traffic North of Boston, MA
Can he make more of those for sale? I'd totally buy one (assuming it's affordable)! And I suspect I'm not the only one by a long shot.
_________________ Be alert! America needs more lerts. Eric Law '14 A6Q 3.0t: fast & getting faster '12 A4Q: not so fast but working on it '90 80Q with AAN and Megasquirt, gone but not forgotten
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Thu May 07, 2020 7:56 am |
Sorry, but no. I'll email you to explain why.
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Mon May 18, 2020 10:24 pm |
So tomorrow the new tires for the bandit should be here! They are classified as an "all season," but with the very straight line tread, I don't see how! They will be mounted on the borbet's from the CQ, and the CQ will be getting the Cab/80 comp wheels.
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Sun May 24, 2020 5:35 pm |
The tires took an extra day to get here, but they did show up. Accelera PHI-R 215/45/16. Fairly soft compound. We shall see how well they hold up.  I took the borbet's off the CQ and cleaned them up.  Got the tires mounted up today and on the car. Quick trip around the block to settle the suspension. I like the look of the semi dished 5 spoke wheels more than the 6 spoke cab wheels
Top |
Rustbucket
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Sun May 24, 2020 6:38 pm |
Redline? |
What are those 16" rims off of?
Sent from my SM-G960U1 using Tapatalk
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Sun May 24, 2020 6:40 pm |
They were on the coupe when I bought it. They are a borbet wheel, but don't know what model they are.
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Sun May 24, 2020 6:42 pm |
That was an easy search... They are borbet type E wheels
Top |
Rustbucket
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Sun May 24, 2020 8:05 pm |
Redline? |
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Mon Sep 14, 2020 10:08 pm |
Well it's been a while, but finally have something to post again. I've been having some major sync loss issues lately. Know that I'm running a hall sensor on the trigger wheel, up front, I doubt that's it. It does it after it gets hot, so I'm figuring the hall sensor in the dizzy is going bad. It's an MC2 dizzy, so figure 1990 ish for build date. I found a new dizzy on amazon by MTC. Listed for "Audi 5 cylinder". I figured for the $23 shipped amazon wanted for it(normally $83) figured it was worth the gamble because the 200 2.2l was listed. Well it came in as a 5 window, so no good there. Now it's in pieces, waiting for me to pull the dizzy from the car and swap shafts.
Top |
sparkyjack
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Tue Sep 15, 2020 4:18 am |
Joined: Thu Jan 11, 2007 6:35 am Posts: 302 Location: West of Baltimore
Interesting.
_________________ Jack The Ring count on my driveway is dropping, I’m down to 4 '90 CQ
Top |
elaw
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Tue Sep 15, 2020 4:19 am |
Two things: 1. A dizzy for $23... damn! I suppose it must be Chinese but that's still crazy short money.
2. Doh! I knew you'd been having sync losses and were concerned about the sensor in the dizzy but never put 2+2 together and realized you were thinking the sensor was responsible for the sync losses. Sorry to say I'm pretty sure that's not the case... I think the MS uses the cam sensor to establish engine position during cranking/starting then from that point forward relies on the crank sensor only (although it may use the cam sensor to resync if sync is lost). It should be pretty easy to test... start the engine, then with it running, pull the plug on the dizzy sensor. I think you'll find the engine continues running just fine.
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Tue Sep 15, 2020 6:06 am |
Well, I'll have to try that. I assumed the crank and cam sensors were used the whole time.
As for the dizzy, it was really cheap! I was looking at them for $83 then suddenly an amazon listing popped up for "last one, $23." Figured at that price I really couldn't lose. It uses the smaller more modern sensor, but that should be fine I would think. That if the swap is needed that is...
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Wed Sep 16, 2020 9:33 am |
Well as Eric stated, I pulled the plug from the dizzy after it was running, and it stayed running... So this happened.  Had to pull the whole front end and intercooler to get to the crank damper. I've always thought that maybe this trigger wheels "missing teeth" were too tall. They are just shallower than the OD of the trigger wheel. Not a great pic but you get the idea  I also found one of the alt bracket bolts was completly backed out and just chilling in the bracket. Yes, I know, I need to get PS hoses, that's the leak you see on everything..  There is also a small amount of oil in the intercooler plumbing. Enough that I felt the need to wipe the small pool out of the coupler when I took off the intercooler. Looks like the seals on the turbo may be going bad. Good think I have the hybrid to put on it haha. My uncle killed my dremel, so I spent some time figuring out what happened, and now I'm tired. I got the dremel working again, and waiting on a reply about cutting that area down some. Now it's time for bed.
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Mon Dec 07, 2020 2:28 pm |
Not much to report on the bandit unfortunately. I haven't done much with it. I need to order a new crank sensor, and a male 3 pin JPT connector. On a different note though, I finally got a Tig welder!  AHP AlphaTig 201XD. They brought the price down to $640, so I decided now was the time to buy. It comes with a #17 and #9 rotaflex torch, but I'm not so sure I like it. I may change it out for a standard #9 flex head torch. There were some reports of these showing up DOA, so I wanted to get it tested as soon as it showed up. I'm going to have to "relearn" how to use this welder on AC. I'm used to the old style transformer welders I use at work. All in all, not bad for a cold piece, and learning how to set it up I think.  Hopefully this means I'll be able to make some more interesting things here at home for the bandit!
Top |
Speedyurs4
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Tue Dec 08, 2020 5:25 pm |
kickin' tires'n lightin fires |
Nice. I have the 201 also but right before they updated the to the nicer pedal
_________________ 1994 s4: O1E 6spd swap, Stromung 3" turbo back,and so on 1983 Audi 4ks Plain Jane 1990 90q 20v: Project? 1990 90q 20v: Parted out/ junked RIP 1982 Honda v45 X2 1995 S6 part cars
Top |
DE80q
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Tue Dec 08, 2020 7:40 pm |
Interesting, I though I read one of the biggest updates with the 201 was with the nova pedal.
Top |
Speedyurs4
Post subject: Re: 10vt into my 80q(the Bandit) Posted: Tue Dec 08, 2020 7:58 pm |
DE80q wrote: Interesting, I though I read one of the biggest updates with the 201 was with the nova pedal. The did the swap like around april 2019 if I recall Sent from my SM-A102U using Tapatalk
Top |
