Post new topic Reply to topic  [ 898 posts ] Go to page Previous  1 ... 29, 30, 31, 32, 33, 34, 35, 36  Next
ABZ Fiero
 Post subject: Re: ABZ Fiero
PostPosted: Sat Dec 01, 2018 2:53 pm
well it is coming along slow as i am trying to get it the best i can to make sure it is all square and right
PostPosted: Sat Dec 01, 2018 7:53 pm
Coming along...
2010 Dodge Ram 4X4 1500
2003 Audi RS6
1991 Audi Quattro Coupe eS2
PostPosted: Sun Dec 02, 2018 1:59 pm
ya it is coming along i just trying to get it all squared awat befor i weld it so good
PostPosted: Mon Dec 03, 2018 4:55 pm
she is short
PostPosted: Tue Dec 04, 2018 10:31 am
Nice work. Good thought on the door brace to keep the chassis correct.
So does this eliminate the sunroof?
Greg W.
PostPosted: Tue Dec 04, 2018 4:17 pm
there was not a sunroof in this car but it would eliminate it if it had one
PostPosted: Wed Dec 05, 2018 7:30 pm
Today i decided that i would be putting in a roll cage it will be a rear hoop with legs that go forward at a angle and some short spuds that go to the rear fire wall right at the rear upper frame rail this should stiffen the car up and i might x brace the rear hoop to give it some torsional twist stiffness
PostPosted: Tue Dec 18, 2018 5:43 pm
well the hoop is tack welded in and the sheet metal i ordered showed up so i can get this welded up right after i go get some more gas for the welder as i ran out today
PostPosted: Sat Dec 22, 2018 8:57 am
Today i did very little on the car and have decided to make sure i take my time on it so i don't stress out about getting it done and make mistakes as i have made a few and had to repair them but it is going good
PostPosted: Sat Dec 22, 2018 2:43 pm
Pictures required!!
2003 Audi RS6
PostPosted: Sat Dec 22, 2018 4:10 pm
i will take some more pictures soon i want to get more done then i will get them posted
PostPosted: Mon Dec 24, 2018 10:41 am
today i did a little bit by putting in one of the rollcage door bars i would have done both but i screwed one up by cutting it to short oh well i will use that for coming off the top of the rollcage to the rear strut towers i also put the seat in to find out how i was going to fit in the car and found my head is right at roof height so i need to do some work getting the seat to sit lower i think i can gain 2 inches of head room by modifying the seat rails and floor seat riser brackets
PostPosted: Mon Dec 31, 2018 9:26 pm
Happy New Year Everyone
PostPosted: Tue Jan 01, 2019 1:58 pm
Happy New Year.
PostPosted: Wed Jan 02, 2019 1:05 pm
How much did you lower the roof, 3"?
PostPosted: Wed Jan 02, 2019 2:19 pm
yes 3 inches that is as far as you would want to go i have started fitting and setting up the body it is going to be allot of fiberglass work
PostPosted: Thu Jan 03, 2019 5:23 pm
a few more pictures of how it is going as i square ,level and position the panels for fiberglassing i should be starting to fiberglassing this weekend
PostPosted: Sat Jan 05, 2019 9:20 am
Today i started to fiberglass it all back together this is gonna take some time to get it looking good and be strong
PostPosted: Mon Jan 07, 2019 12:15 am
You will get there. Just take your time. Maybe some reinforcement on the backside of the glass, either wood or metal.
Greg W.
PostPosted: Mon Jan 07, 2019 5:01 pm
I agree just take my time and i need reinforcement on the underside to make sure it stays where it needs to be
PostPosted: Tue Jan 15, 2019 9:44 am
I riveted the bumper back on i moved it in 1 inch and squared it to the top so the gaps around the tail lights ar tighter and even i also put some braces on the underside of the rear body so the right side stayed flat and not tilted from inside out it is slow going but t takes time to get the way you want
PostPosted: Tue Jan 15, 2019 12:12 pm
That is going to look so good that you will have to finish the interior! ;)
PostPosted: Tue Jan 15, 2019 12:52 pm
Oh no not the interior lol i wish i knew how to build a custom interior as it needs one to go along with the exterior as custome as it s the stock fiero interior is really not nice enough
PostPosted: Wed Jan 16, 2019 1:38 pm
Sanding body filler is just so much fun it is as fun as sheetrock compound oh well this just how t is you sand the put more filler on then sand check it and just keep doing this process over and over until it is good and straight
PostPosted: Fri Jan 18, 2019 1:50 pm
well today since it is slow i am playing with the rear deck lid i am using a GT lid and have cut the back off the kit car lid and am attaching it to the GT lid this is giving me a much better fitting deck lid and better looking when shut or open
  |  It is currently Sat Nov 28, 2020 6:11 pm
