Post new topic Reply to topic  [ 898 posts ] Go to page Previous  1 ... 30, 31, 32, 33, 34, 35, 36  Next
ABZ Fiero
 Post subject: Re: ABZ Fiero
PostPosted: Sun Jan 20, 2019 9:47 am
just wanted to show how much better the taillights fit the first pictures was how they were before with some really big gaps now they fit nice and tight but i still need to do a bit more messaging but it is 90% good. you can also see the right hand side rear dips down from the inside to outside
PostPosted: Wed Jan 23, 2019 8:03 pm
I am liking the new roof line.
Greg W.
PostPosted: Thu Jan 24, 2019 5:36 am
yes the new roof line looks really good i am trying to have the car back on the road by may and i don't see any reason why it wont be i just need to keep pecking away at it .
PostPosted: Sun Jan 27, 2019 10:56 am
well i threw the roof on just to see i did cut it as it needed to be shortened up and i have taken a few days off from it and will get back on it soon but i figure i have until May, as i would like to go to the home depot car show if they have it
PostPosted: Wed Feb 06, 2019 7:58 pm
today i bought a W8 passat and after i am done with the project at hand i will swap the engine out from the passat into a fiero as this engine is so short for a 8 cylinder i will not need to even touch the firewall at all and it will be a longitudinal install i am thinking a 5 speed automatic the 5hp19 tiptronic i will do a build thread on it but it will at least 6 months away
PostPosted: Sat Feb 16, 2019 9:20 am
today i sanded the fiberglass for the rear bumper that i laid and spread some filler that i will sand tomorrow and then spread some more filler
PostPosted: Sat Feb 16, 2019 4:58 pm
Only a suggestion, but I was use something else besides an Audi Automatic. They do not last.
Greg W.
PostPosted: Sat Feb 16, 2019 6:25 pm
well that project for the w8 engine is at least 6 months away i do know that they make a stronger drum that fails but i don't know if turning up line pressure will help on the 5hp19 and my chop top car that has the 4.2 has a 012 manual transmission and i might just go with that transmission in the w8 project
PostPosted: Sun Feb 17, 2019 4:00 pm
today i did a little bit to the rear section as i sanded the filler and spread a second coat of filler and i think it will take another coat or 2 of filler to get the rear bumper all blended in , after that i will flip it back over and put it back on the car and finish it up then i can move on to the front section of roof and that should not take long nor should the trunk or front end cracks
PostPosted: Mon Feb 18, 2019 1:23 pm
it is looking pretty good on the bumper but i want to put this back on the car so it is sturdy so i can finish it all up
PostPosted: Wed Feb 20, 2019 5:41 pm
Sometimes you just need to mock it up so you can get motivated and it worked for me as in my opinion this is gonna be a sick looking car if i can do a good job at finishing it up
PostPosted: Wed Feb 20, 2019 6:39 pm
That first spray of primer should really assist with the motivation as well.
2010 Dodge Ram 4X4 1500
2003 Audi RS6
1991 Audi Quattro Coupe eS2
PostPosted: Thu Feb 21, 2019 4:39 pm
yes i cant wait to see it in primer i might even consider a color change to Viper yellow
PostPosted: Fri Mar 15, 2019 11:43 am
tomorrow i will get the dors all prepped to i can bond the fiero door skins to the kit car door skins as you can see they are fit and just need bonding they are riveted on right now
PostPosted: Sat Apr 06, 2019 5:52 pm
well i have the kit car door skins all bonded and fiberglassed and looking good so now i have moved on to the quarter panel scoop i have been working it during my free time at the shop so some days i do alot and some nothing at all
PostPosted: Sun Apr 07, 2019 2:01 pm
The w8 engines do sound good but they are extrememly fragile and VW do not make spares for the bottom end. You will be losing around 100bhp from the a8 engine to the w8 engine.
What is the rest of the w8 like? was it a saloon or wagon?
PostPosted: Mon Apr 08, 2019 8:44 am
the w 8 engine is a whole different project than this car i am just looking to see how well it fits
PostPosted: Sun May 12, 2019 4:04 am
i was going to spray high build primer yesterday but got called away by my dad saying he could not breath so i called 911 and went make sure he was alright he is 89 years old and still wants to work like he is 35 + he has Bronchitis so after the big scare i stayed with him the rest of the day and he is fine now with today being mothers day i won't try to get someone to help me with the pulling rear body as am painting body off
PostPosted: Tue May 14, 2019 3:52 am
damn it i woke up this morning and see snow i hope it warms up for this next weekend so i can paint what i wanted to do last weekend. May 14th and snow this really sucks
PostPosted: Wed May 15, 2019 9:37 pm
Glad you Dad is doing ok.
Greg W.
PostPosted: Thu May 16, 2019 2:56 pm
He is doing much better now and i know one thing i hope i have that much drive to do things when i get to that age of 89 as he gets around well go's golfing and drove himself home from FL 1600 miles in 3 days . well tomorrow i am planing on finally getting primer on the body as have only a few inspections in the morning .
PostPosted: Fri May 17, 2019 4:34 pm
i did not get primer on it today but it is all setup for priming i just need to do a bit more sanding as i found a few things i didn't like so wanted to fix them it is not going to be show wining quality but it will look good as won't be embraced by how it looks
PostPosted: Sat May 18, 2019 11:42 am
well no red paint tomorrow as there is much more sanding and smoothing to do after spraying it with primer but i will get it done before the summer is over
PostPosted: Sat May 18, 2019 8:04 pm
I would love to be able to take a body apart like that to do work on. Makes things a lot easier. Wow.
Greg W.
PostPosted: Sun May 19, 2019 12:48 am
yes it is nice to be able to pull the body off so you can paint it or work on it or even the chassis
  |  It is currently Fri Nov 27, 2020 1:04 pm
