Post new topic Reply to topic  [ 898 posts ] Go to page Previous  1 ... 32, 33, 34, 35, 36  Next
ABZ Fiero
 Post subject: Re: ABZ Fiero
PostPosted: Fri Jul 12, 2019 2:43 pm
thanks for the compliments as i know i love the look of the car and am glad other like the car as that means alot to me as since i was a young guy i always wanted a sports car that looked excotic and i think i have don it . i have been working on getting the mufflers tucked up and away so i have good ground clearance and are hidden from sight and right now it looks like they are going in at a 45 degree angle
PostPosted: Fri Jul 12, 2019 4:37 pm
My next project will be a VW passats W8 engine in a fiero as it should fit like it was made for the fiero
PostPosted: Tue Aug 20, 2019 5:22 pm
it has been awhile since i have been on but i have made some progress with the car I actually took it out for a drive today and it ran pretty good it has a few things that need to be done on the tuning and i would love to go back to EFI express and have Marc tune it but for now i will try to work the tuning out my self
PostPosted: Thu Aug 22, 2019 6:13 pm
Nice. You know, that Mark can tune remotely. You have wifi, hook up your computer and have him work his magic.
Greg W.
PostPosted: Fri Aug 23, 2019 3:20 am
I would need to go out and do some logging driving it on the street not really the smart thing to do on the street running it up 7000 rpm going through the gears i know doing that is fun as i have done it in the past but try not to do that stuff anymore i like to go to the race track to do that but the drag strip is just as far away as Mark is
PostPosted: Fri Aug 23, 2019 5:24 pm
worked on the exhaust and got some hangers on it and then i did one of the fastback inner trim parts that needed t be cut down i have not finished it yet but it is put back together using K tool Q-bond it works great i will do the driver side trim part tomorrow then all i need to do is make sure i smooth them out with filler and paint them with trim paint
PostPosted: Sat Aug 24, 2019 10:31 am
today i did the driver side fastback trim and now i just need to do all the body work them to smooth them all out then prime them and spray with trim paint
 Post subject: Re: ABZ Fieroto /4
PostPosted: Thu Sep 05, 2019 7:39 am
anyone running a megasquirt 3x can i ask what you set the gain at for your knock sensor i have set mine all to .5 as i had the gain to high and just sitting and running the car and reving it was setting off the knock sensor and retarding the timing but i know they should be a bit different for each cylinder as they are closer or further away from the knock sensor
PostPosted: Tue Sep 24, 2019 8:13 am
Not sure this will help anyone but i was messing around with the Water/methanol control on the megasquirt 3x and i found i had the Hz set wrong for the solenoid as i had it to high so it was not running the solenoid on lower duty cycle like 30 percent duty so i was not getting any injection at 5 pounds of boost but now that i have it working right i can make a map of how much water/meth i need at x amount of boost and rpm giving me a better methanol delivery for better performance
PostPosted: Mon Sep 30, 2019 1:03 pm
this is almost the finished look of the car exterior except rockers and maybe some black accents in the door cove area
PostPosted: Tue Oct 01, 2019 2:55 am
i don't understand why the picture is upside down in my last post
PostPosted: Wed Oct 02, 2019 8:48 am
Looks great.
PostPosted: Wed Oct 02, 2019 9:30 am
i need to go back down to see Mark at EFI Express to finish tuning it and dyno to see what it will do for number
PostPosted: Tue Oct 08, 2019 3:24 pm
Mark is a whiz.
PostPosted: Tue Oct 08, 2019 5:04 pm
He is smart but i saw a deal on a Dynamometer it is a mustang chassis dyno that was for emission testing but i am going to upgrade its software and eddy brake if needed videos and pictures are the dyno i bought
https://www.youtube.com/watch?v=1u33Yth ... AiigsVFpyw
https://www.youtube.com/watch?v=BFuMdMw ... upCy9h3wk0
PostPosted: Sun Oct 13, 2019 6:13 pm
chassis dynamometer is all picked up and in my shop i have much to do to get it running most of it is cleaning it up and making it pretty . I have talked to some who have the same dyno they say you can do up to around 500 whp that will cover what i want to do
PostPosted: Tue Oct 15, 2019 3:36 am
ok the 18 gauge sheet metal came in for the fiero rockers came in now i need to move the dyno so i can lower the fiero and make the rockers so this should happen in the next few weeks then she will be going to bed for the winter in the inclosed trailer i bought . life is good right now as i have a bunch of projects going on and i like it
PostPosted: Wed Oct 16, 2019 5:50 pm
Must be nice having a personal dyno. :D
PostPosted: Wed Oct 16, 2019 6:15 pm
it was cheap but it will do what i want as it is a old smog dyno with eddy brake, i need to spend $800 for software and data acquisition / brake controller and i have a 20 + foot camper trailer given to me the camper is junk ut the frame is strong and in great shape for mounting this dyno so i can travel with it and dyno a car if someone wants and the car owner can tune it or try to tune it
PostPosted: Wed Oct 23, 2019 3:44 pm
Since i bought the dyno i have been feeling like a little kid as i can't wait to get the fiero up on my new toy to tune it
PostPosted: Sun Nov 10, 2019 12:45 pm
today i got after it on striping the camper body off the trailer it is now off and just the floor is left but i think that will rip right off with the truck in 4 wheel low and a strap hooked on and just rip away it will be dyno ready soon
PostPosted: Fri Nov 15, 2019 2:16 am
Been following along on the build. Awesome work!
A one of a kind car you have built here.
Definitely in for some dyno numbers.
1988 80 quattro- 12.7 and 109 mph([email protected] with my slow shifting)
C5 A6 Avant- Wagon for the kid
1991 90 20v- Gone, but still close to my heart
-Eric
PostPosted: Fri Nov 15, 2019 4:20 pm
i would love to do some dyno runs but now it is cold and we have just a little snow so it won't be until summer
PostPosted: Wed Nov 27, 2019 7:25 pm
Happy Thanksgiving everyone
PostPosted: Thu Nov 28, 2019 5:48 pm
Happy turkey day!!
------steve
1990 Audi Coupe
Users browsing this forum: No registered users and 6 guests
  |  It is currently Tue Oct 27, 2020 7:47 pm
