Post new topic Reply to topic  [ 306 posts ] Go to page 1, 2, 3, 4, 5 ... 13  Next
Afterthought's 83 Ur Quattro
 Post subject: Afterthought's 83 Ur Quattro
PostPosted: Mon Sep 07, 2015 8:19 am
Finally was able to find an Ur Quattro, after many times of offering cash and being told "not for sale" I found one in Texas from an audi enthusiast some of you might know, anh had the car transported up here to Washington.
The car was advertised in non-running condition needing some CIS and/or Wiring work and came with a ton of extra parts, including a 3B in need of a rebuild.
So here's the story on the car.
It was purchased from the first owner in 2002 by the previous owner who had it garaged and was running until he did some work to swap in a later 4000 fuse board and thinks maybe something pulled loose after or the diagrams are likely wrong. The interior is gutted to get to the wiring, most of the dash is out. He sourced a 3B to do the swap (needs rebuilt) and never go the 10vt running, so the car sat for years in a garage and eventually became for sale.
Excerpt from for sale ad:
Non running at the moment.
84 Fusebox under hood.
84 4K parking brakes.
late 83 diff controls.
Car has been garage kept since 2007.
spent a year outside under car cover.
Bough in 2002ish from New Jersey.
Dr. Bernardino's old car. I think he was the original owner.
Assortment of parts obviously.(no rally parts)
$10K.
Will throw in 3b engine that needs rebuild.
3b engine wiring harness.
RR airbox
Euro bumpers F+R
15x8 ronals refinished
15x8 BBS
Sloped Euro Cibies, three or four. Enough for a set.
Sloped front grill.
Mocha Leather interior
good floor carpet from a black 4K.
Clean title.
Rust on Shock towers has been welded up and POR-15
10V engine is in the car.
non cracked dashes.
X2 white vinyl rear wing uncracked.
Spent some time trying to come up with a plan and spoke to a few enthusiasts regarding what to do (fix CIS? or start swap? 6sp vs. 5 spd? etc)
Decided to immediately tear down the 3B and get it to the shop to get hot tanked and get the bores checked, and proceed with some valve work and what not on the head.
Then take a look at CIS. This way if I can't get the CIS to run it wont matter, because I'll have acquired much of the stuff I need for the 3B and will proceed with that then.
Using this are as a "scratch paper" to document my goals/questions/though for where I want to car to be in the future and where it is currently:
PHASE 1:
-Clean up, change fluids and battery, do some quick troubleshooting on the 10v. It had air and fuel. Need to find out why it wouldn't spark.
-If the CIS looks like a dead end, then proceed with pulling the engine now and execute phase 2.
Phase 2:
-Source parts to rebuild 3B (top/bottom end gasket set, upgraded rods, t-belt, arp head studs, resurface head and block) . There was a broken cam pulley/t-belt so may have been some interference. (9/3/15 Ordered parts. Head valves for Cyl 2 and 4 did hit the pistons. Will be doing wither 3B head with new valves or AAN head. AAN looks to be in better shape. Will verify with the machine shop tomorrow.)
-3B Engine swap (Engine rebuild in progress 9/3/15)
-VEMS Econoseal with custom VEMS harness (ordered)
Phase 3:
-Upgrade suspension
-Upgrade brakes (want this thing to stop like my s4 does)
Phase 4:
-Forward Facing intake manifold (will do a custom one using TIG / T6061 Aluminum)
-Custom exhaust
-Custom Exhaust manifold
-upgrade Turbo
-01E or "TDI" 6 speed
-Ultimate goal is 400 Wheel, should be easily obtainable and I want to build this car in such a way to leave me more headroom if I want to go up.
Parts:
New fuel filter - 09-05-15
New Ignition Coil - 09/06/15
Couple of pics.
Afterthought
Current:
 Post subject: Re: Afterthought's 83 Ur Quattro
PostPosted: Mon Sep 07, 2015 9:40 am
Some pics of the general condition of the car as it was delivered. Last week.
Cosmetic attention needed as it appears to have been covered in paint overspray, will take some serious elbow grease but that can be fixed. Most importantly, the body is straight and has no dents!
At one point the front fenders were pulled off and the shock towers were fixed, the fenders were lined with por-15 on the inside which is a cool idea.
Exterior:
Pulled off a Fender to see what the preventative POR-15 rust repair looked like:
Couple quick shots of the interior:
Its all there, but the front of carpet is out, lower dash and glovebox is out to access wiring. Cluster, etc. out
Current state of the engine bay:
Underside:
One problem area to note:
Spares:
SQ manifold. Has a crack.
RR airbox
3B and harness:
The 3B engine sustained some contact to the front, enough to break the cam sprocket. More to come on that.
Afterthought
Current:
PostPosted: Mon Sep 07, 2015 9:44 am
Took some time today to work on the car, no power to the windows so I used a wire and battery to roll up the drivers side window so I could push it outside to pressure wash the car...
There looks to be paint yellowish paint overspray over the whole car and windows. Everything except the front fenders since they were off. Not sure how I'm going to get that off.
Started washing until a lightning storm went directly over my house then the power went out. So I got to work pulling the 3B apart by flashlight.
The valves on#2 and #4 have a visible mark where they contacted the pistons. So I'm either going to put new Ferrea valves in this head, or use my spare AAN head with stock valves.
Looks like this plastic cover and the cam gear were the only casualties of the contact on the front pf the engine.
Afterthought
Current:
PostPosted: Mon Sep 07, 2015 9:46 am
Finished getting the engine down to just the block.
I have been really happy with everything I have seen so far which is great news. I don't want to have a single worry about this engine when it goes together.
The bearings all appear to be stock to me but I'll have to measure/
No major scoring on the surfaces anywhere.
Afterthought
Current:
PostPosted: Mon Sep 07, 2015 9:58 am
Wiring time>
So I've cleared up a few things.
My car has the factory flange installed for the underhood fuse box and since my vin is #603 and it is one of the first ones to come with this.
At some point the PO noticed some hot spots on the bottom of the factory fuse panel so he swapped it over to a later 4000 fuse panel, after doing this the car would not start. So what I have should be very close to the 85 turbo quattro but may not match the diagrams 100% since these were hand wired.
http://homepage.ntlworld.com/jh.666/wiring/relays.png Harness from an 85 turbo quattro.
This is what I've got under the hood.
Handy link.
http://forums.quattroworld.com/quattro/msgs/957.phtml
Sat 9/5/15: Worked on the wiring a bit today.
Upon receiving the car I installed the instrument cluster and had no lights or anything on it, no appearance of power anywhere other than brake lights.
Today I found my extra fuse panel from a 1995 audi 90. The panel is almost identical so I used this to help me with the orientation since I cant flip the one inside the car upside down, comparing with my diagrams of how everything should be. I changed only one terminal as far as I know and now have power to the inst. cluster.
I had a buddy drop by so I used his help for a minute to test the power at the fuel pump (have +12v with ignition on) and the power to the ignition coil (have +12v with ignition on) When cranking the fuel pump will turn on, but the ignition coil out is not producing a spark.
Also, Sounds to me like when I am cranking the fuel pump is only bumping on every few seconds? Which I don't think is right...
Sunday 9/6/15:
Installed new ignition coil, no change. Trying to troubleshoot if the issue is wiring and fusebox related (most likely) or just a bad Ign. module.
Tested the following per phil payne's website.
-have +12v ignition on between Pin 2 and 4 on the ignition module plug
-pin 1 at the ignition module plug has continuity to pin 1 of the coil. So that wire is good.
-pin 2 at the ignition module and body ground have good continuity.
-pin 4 of the ignition module plug has continuity to pin "15" on the coil.
-Pin 6 on ignition module plug has continuity to ECU pin.
So this should tell me that the wiring is good from the ecu and "pos" to the coil. But I am a little thrown off by the fuel pump not staying on while cranking.
Afterthought
Current:
PostPosted: Mon Sep 07, 2015 10:27 am
I boggle like it's my bidniss
Impressive!
Might be time to get that chassis on a rotating table to clean the underside. I am going through the same thing now with a Coupe.
Issam N. Abed
iABEDIndustries.com
PostPosted: Mon Sep 07, 2015 10:48 am
Looks like James sold you a good solid car.
It should be a great project!
It will be worth it in the end.
If you have a 5 cylinder, you don't need a stereo
Homologation car junkie.
PostPosted: Mon Sep 07, 2015 11:25 am
Wizard-of-OD wrote:
Impressive!
It will need some attention but some preventative work was done at least. I have a spare set of fenders for the front so I'll see which is in better shape . I don't have a rotating table, what do you use?
Afterthought
Current:
PostPosted: Mon Sep 07, 2015 3:22 pm
Afterthought wrote:
Wizard-of-OD wrote:
Impressive!
Make one using 2 engine stands.
Issam N. Abed
iABEDIndustries.com
PostPosted: Mon Sep 07, 2015 3:50 pm
It ill clean up well!
Looking forward to doing the 3B swap on this and going a different route that I did on my previous 1990 coupe.
You're in Portland, huh? Seems like are quite a few Audi guys down in in that area!
Afterthought
Current:
PostPosted: Tue Sep 08, 2015 3:17 pm
:-D Yes! There's a strong number of urq's in the PNW. 15 or so..
PostPosted: Tue Sep 08, 2015 6:09 pm
Aren't there a couple of turbo 4000's down there too, or no?
I have a friend who used to work at sunset Audi as a tech. But that was years ago. Had a turbo 4000 unfinished project that I got from him, one of my first cars. First turbo car. From there it was downhill Ha.
Anyway I remember him talking about some of the older Audi stuff down there and with SJM autotechnic and other places down there seems like there is a good bit of knowledge and appreciation for the older cars!
Afterthought
Current:
PostPosted: Tue Sep 08, 2015 6:17 pm
I think there were at least 3 20vt 4kq's at Audi Expo this year. There's a few 10vt 4kq's around too.
-Alex- @vexartmedia on Instagram
1992 Porsche 968 (07K transplant in progress)
1983 Aud UrQ (MC1, GT2871R, IIc)
2003 Audi S8 (DD)
Past Audis: 87 CGT, 87 4kcsq, 93 S4, 90 CQ, 87 5ktq, 95.5 S6Avant, 86 CGT CE, 95 90qs 1.8T, 83 UrQ, 87 CGT 7A
Past P-cars: 80 931, 87 924S, 87 951
PostPosted: Thu Sep 10, 2015 5:02 pm
Well this morning I decided I'm done fiddledicking around with CIS.
It's at the point where its going to cost me more money and time to get it up and going with the WX, and my ultimate goal was 3B anyways so I'm proceeding on to that now.
Started getting the CIS out of the way, Radiator out, disconnected drive shaft. Now I'm stuck on tie rods, Seems like there is no way these are coming off. After disconnecting all the fuel lines I didn't feel like using a torch right there but I did everything short of that (with what tools I had)
Going to try and find something for the tie rod. Then get everything out of the engine bay and so some paint touch up.
What's the thought on brake booster conversion to vacuum? Is it necesary? is it a good idea?
Afterthought
Current:
PostPosted: Fri Sep 11, 2015 5:34 am
For the tie rod connection to the rack, there are nuts below the rack on the bolts that hold the tie rods in. The rack is threaded, and the nuts below act at jam nuts to lock the bolts in place. Remove the nuts below, and then you'll be able to remove the bolts from above.
Nathan Engelbert
83 UrQ DA900453
95 S6 avant
PostPosted: Fri Sep 11, 2015 8:14 am
Congrats on the acquisition and best of luck on the build. If that's your workspace on your property...that's Badass!
DFrosty
2003 A4 1.8T...Daily Driver
1991 90q 20VT...'Project Setback'
1983 Urq 20V...'Project In Perpetuity'
PostPosted: Fri Sep 11, 2015 10:53 am
Thank you sir. I didnt realize the top was threaded too. However which way I think I still have to get the ends off to drop the suspension out. Suppose I could try to take the inner ends off and go from there. What I think I need is a tie rod/ ball joint separator tool from the auto store. Should make quick work of that.
Afterthought
Current:
PostPosted: Fri Sep 11, 2015 10:55 am
Thanks buddy. Got really lucky when I found my place, had an empty 3600 SQft shop on it, looked at the house and immediately put in an offer.
Afterthought
Current:
 Post subject: Inner Fenders..
PostPosted: Fri Sep 11, 2015 3:58 pm
IF you have your fenders off, would be a good time to install the plastic inner fender linesrs form a 4k or coupe.
IS the reason that 4k & coupes don't rust up in the strut and upper fender areas, that are common problem areas on the urq..
-=Frank=-
Image <- "The Twins" Image
 Post subject: Re: Inner Fenders..
PostPosted: Sat Sep 12, 2015 5:30 am
Frank, yes they are both off currently and I'd love to fit some liners in there.
I Need to find a 4000 parts car!
Afterthought
Current:
PostPosted: Sat Sep 12, 2015 6:36 am
Just hit the arm on the strut where the tie rod goes through, try and avoid hitting the boot. A few good whacks and it will fall right out. I assume it's steel like a 4kq. I do this all the time works for ball joints too.
PostPosted: Sat Sep 12, 2015 3:45 pm
I will try it. But probably going to stop and get the tool anyways if I can remember.
Found a 4000 brake booster so I will try and see if i can track down a part number for the Master cylinder I will want to go with that. I think it's out of a 90-91 200Q or V8, can anyone confirm?
Afterthought
Current:
PostPosted: Mon Aug 29, 2016 12:05 pm
Quite a few updates here that I was slacking on.
Removed stock 10vt
Painted engine bay (started as what was going to be some "touch up" with a spray can and got out of hand)
Painted front fenders and euro bumpers
"Paint correction"
Lacquer thinner to clean up the windows
The top:
Passenger side:
This is after one pass with Meguiar's Diamond Cut 2.0:
After one pass with the eraser pad.
The overspray on the drivers door is so thick I honestly don't know how to get it off. Maybe lacquer thinner? If applied carefully
Painting fenders
Painting engine Bay
This is what happens when you think "I'll find a can or aerosol paint to touch up the engine bay a bit."
The result is a complete respray of the engine bay in factory color.
Engine bay was completely sanded and prepped for days, then wiped down with dirt and grease remover, wiped dry, blown dry.
Then wiped down with a tack rag. Then sprayed in sealer.
Coated in factory paint.
Afterthought
Current:
PostPosted: Mon Aug 29, 2016 12:07 pm
Had to get the car moved off the lift to do something to my 4000, so time to get the suspension on.
Extracting a broken bolt for the rear ball joint
Completed strut
In the car
Spherical Comp Brake mounts from Marc. These are awesome
Starting to re-install things in the engine bay
Fronts together
Nice to see the car back on the ground. need to do some work to the suspension but next thing to tackle on the Coupe is the Brakes.
Afterthought
Current:
PostPosted: Mon Aug 29, 2016 12:09 pm
Engine stuff
Not sure exactly where I left off but I started to re-flange my manifold to V-Band this morning to facilitate running the EFR turbo which is V-Band in/out.
I can't remember who makes this manifold as I got it from another forum member but the only issue fitting up is I had to shorten one stud and there is kind of a sequence for getting the manifold partway on then adding the nuts on two spots in the bottom- as the runners are so close to the stud.
On the engine I don't have the AAN Cam sprocket bolt and It's not the same as the 10VT WX bolt so I'm going to have to track one down.
Got it all snug and will leave this here for now until I start fabbing a downpipe.
Need to find a suitable puller to get the stock pilot bearing out of the 3B and put the correct one in there, then I can get the clutch on and trans in.
Afterthought
Current:
Users browsing this forum: No registered users and 5 guests
  |  It is currently Wed Aug 05, 2020 5:59 am
