Post new topic Reply to topic  [ 6 posts ]
2.2 10v or 20v
 Post subject: 2.2 10v or 20v
PostPosted: Fri May 15, 2020 3:27 am
Hi All
I have purchased a B2 Audi 90 quattro.
Im looking to add a turbo but it looks like im best to purchase a motor with a factory turbo set up.
Any advice and direction would be awesome and also where to source what I need.
Thanks
 Post subject: Re: 2.2 10v or 20v
PostPosted: Fri May 15, 2020 5:15 am
So it all depends on what you want. If you are going for all out power #'s, then I'd say go 20vt. If you just want more power than the JT puts out, and are ok with CIS, would could swap in a 10vt.
I swapped a 10vt MC1 from an 86 5000cs into my B3, but I hate CIS. Because of my hatred for CIS, I also upgraded to EFI via megasquirt.
PostPosted: Fri May 15, 2020 2:22 pm
I recommend a 20v engine...in so many ways better for not much more work, even if left in stock trim. As DE80q notes, going EFI on a 10v is also a fine choice. Seems a waste to spend the energy to transplant a motor but stay with CIS.
Cheers, Eric
1982 Urq 20vt
PostPosted: Fri May 15, 2020 2:57 pm
if you do the work, go 20vt
PostPosted: Fri May 15, 2020 9:41 pm
Im currently having trouble just testing the fuel pressure with my CIS on my 10v 90, CIS sucks. As Dave said, both engines are a fine choice it just depends what you want. If you go 10vt, youd be better off doing an efi swap during the engine swap because CIS is just not worth the hassle. I chose the 20vt and Im currently in the process of rebuilding the engine I bought. Im not sure about the prices for 10vts but I got my 20vt for a little bit over a grand, just to give a sense of the price of the 20vt. Though mine was sitting for a couple years and was in need of a rebuild, so a healthy one that is ready to be dropped in will normally be closer to the $2k mark.
I'd say go 20vt, Ive never worked on a 10vt but I did some research before making the choice and Ive found that the aftermarket is bigger for the 20vt. If you want to build it up and start pushing the numbers, go 20vt. If you don't care about horsepower, just buy which ever engine you find first that fits your budget.
In terms of finding an engine for sale, the fastest way to do this is Facebook. Join some groups and post some WTBs. That's where I got mine.
1988 Audi 90Q 10v - AAN Swap in the works
https://www.motorgeek.com/viewtopic.php?f=6&t=218089" onclick="window.open(this.href);return false;
PostPosted: Sat May 16, 2020 4:32 pm
Theres actually a 10vt for sale right now from a guy on this forum username is Hoosierman. Heres the CL link:
https://fortcollins.craigslist.org/pts/ ... 42819.html
  |  It is currently Mon May 25, 2020 4:38 pm
