motorgeek.com :: Board index :: The Tech Lounge :: Suspension
Post new topic Reply to topic  [ 18 posts ]
B3 82mm front knuckle part #
 Post subject: B3 82mm front knuckle part #
PostPosted: Mon May 11, 2020 3:33 pm
I have a 91’ 80q with cast front control arms. I’m in search of the part # to convert it to 82mm bearings so I can do the 5 bolt conversion with urs front hubs. I’ve come across several different numbers and would like to get the right ones. Any help?
Lite some tires and start some fires
91' 80q
 Post subject: Re: B3 82mm front knuckle part #
PostPosted: Mon May 11, 2020 8:48 pm
cast control arm is forged.
cq, 20v 90 has the proper knuckle for the 82mm wheel bearing
PostPosted: Tue May 12, 2020 1:34 am
I'll look and see what etka has to say in the morning Andy. You could also find a set of B4 knuckles and strut housing to do the same job.
PostPosted: Tue May 12, 2020 3:54 am
Ok great. Thanx guys! That pretty much answers my question. Just didn’t want to find out however long later they are wrong that’s all
91' 80q
PostPosted: Sat May 23, 2020 3:26 am
Don't use urs hubs. Use regular c4 quattro rear hubs.
You'll have wrong offset with urs hubs.
PostPosted: Sat May 23, 2020 7:58 am
c4 quattro rear hub has the same offset as the CQ and S2.
urs4/s6/v8 hub has a bit extra offset, but not wrong, many many ppl were using it successfully in the past.
His biggest problem is the knuckle
PostPosted: Sun May 24, 2020 4:04 pm
And about the hub carriers, 20V and V6 difference is bolt holes, 20V uses M12 bolts and V6 uses M14.
As all the B4 in the US were V6, then you just buy any V6 hub carriers and uprights, buy c4q rear hubs, machine off 5mm to clear the hub carrier.
And you have 1:1 copy of S2 hub and hub carrier combo.
Stock offset, stock discs, stock calipers. No need to find a disc, caliper carrier + caliper compo or use somekind of adapters.
urs4/s6/v8 hub has less offset. Track will become narrower.
urs4/s6/v8 on the left and S2/B4 front hub/C4q rear hub on the right
PostPosted: Sun May 24, 2020 5:36 pm
Ok. But as of now I need to use 4 front urs hubs so I can have 4 front b5 s4 inner and outer cv’s all the way around. The axle shafts I haven’t gotten yet but will be getting soon.
91' 80q
PostPosted: Sun May 24, 2020 9:33 pm
I think i was one of the first one who used this c4 q rear hub on the front of my cq, like 6 years ago
However the urs4/6 is more common and they are disk/bracket combos out there, so doesnt really matter which one you buy.
(i assume nobody wants to use the stock g60....)
PostPosted: Mon May 25, 2020 5:57 am
G60’s would be fine by me. Just not sure what to use for bolt on oem brakes front and rear. I don’t want anything fancy or something hard to find and expensive
91' 80q
PostPosted: Mon May 25, 2020 12:28 pm
Regular C4 quattro hubs use same CV joints as urs ones. For front you can you use V6 driveshafts and CV joints, bolt on to S2 / urs / c4 q hubs.
For rear you'll need to machine the hubs and use other bearings to fit the 82mm hub to a 75mm carrier.
PostPosted: Mon May 25, 2020 5:08 pm
on the rear you can use b5 a4 q rear hub, 75mm bearing
a few mm wider, however works well with urs4/6/V8 rear brake caliper, or D2 S8 alu, B5 S4 rear caliper bracket and disk
(these are cheap parts, easy to obtain, and great upgrade)
I did it many times on urq, b3 90q, b3 cq
PostPosted: Tue May 26, 2020 10:21 am
Ok. Will c4q rear hubs spline into front outter b5 s4 cv’s
91' 80q
PostPosted: Tue May 26, 2020 11:41 am
I don't know if B5 cv's clear the hub carrier. Splines should be the same. "Big" hubs have 38 teeth. 90 V6, S2, C4 regular and S.
Why do you want to use B5 cv joints?
PostPosted: Tue May 26, 2020 3:43 pm
The guy on the S2 forum makes shafts to fit all 8 front b5 s4 inner and outer cv joints at all 4 corners of my b3. Using 4 front urs hubs with a 6mm spacer. Using a bmw e36 rear wheel bearing part# 33412220987 which is 42x75x37. I would need to machine 2 urs front hubs down to about 42.2mm to work.
91' 80q
PostPosted: Tue May 26, 2020 8:36 pm
why do you over complicate a simple thing?
If you really want a stronger axle, get a B3 FWD (manual) for the rear of your car, and a B4 FWD (manual) to the front and call it a day.
That will be good for 560whp, 40 psi
PostPosted: Thu May 28, 2020 7:53 am
I could never really find any other way until you just told me. Thank u!!! But there’s still one predicament. Available parts to fix it. B5 S4 cv’s are readily available
91' 80q
PostPosted: Mon Jun 01, 2020 3:59 pm
B5 cv joints don't fit into B3/B4 hub carrier. At least not with the ABS ring.
  |  It is currently Mon Mar 01, 2021 6:51 am
