Location for Oil Temp Sensor 1984 WR
 Post subject: Location for Oil Temp Sensor 1984 WR
PostPosted: Sun Jun 07, 2020 11:58 pm
Just fitting Oil Temp and Oil Pressure gauges to the WR. I can fit a Oil Pressure sender/switch in place of the current switch no problem. Where is the best spot for the oil temp. I know there is a blank plug just behind the camshaft pulley but I assume this is a spot for coolant temp? There is also a blank on the rear of the head, once again is this water or oil? Where else do I look. Bentley isn't much help either.
Current - 2007 B7 RS4 Avant, APR Stage 3, Milltek with Hi Flo Cats, GruppeM intake, Sachs Clutch, Factory Ceramics, JHM Shifter, RS6 FBSTW, AMI & Hi Res RSNE
Current - 2012 B8 A4, 2.0T Quattro Avant SLine
Current - 2001 B5 S4 Imola Yellow Avant
Current - 1989 B3 90 Quattro - 7A NA Engine, (Long Term Restoration Project)
Current - 1984 WR Ur Quattro
 Post subject: Re: Location for Oil Temp Sensor 1984 WR
PostPosted: Mon Jun 08, 2020 7:49 am
maybe
PostPosted: Mon Jun 08, 2020 11:43 pm
varia wrote:
maybe
I found the same diagram. I think I need to remove the plugs and see if it is oil or water behind.
  |  It is currently Tue Jul 14, 2020 6:06 am
