Garage Cleanout, B3 Quattro Script, UrQ 016, 3.0T, TSW
 Post subject: Garage Cleanout, B3 Quattro Script, UrQ 016, 3.0T, TSW
PostPosted: Tue Jul 21, 2020 10:44 pm
Time to get rid of the parts I've been holding onto for someday projects and focus on the current ones. Located in the Los Angeles south bay area and prices are OBO. Local pickup is greatly preferred but can ship at your expense unless otherwise stated.
B3 Quattro Script Interior, manual front seats - $250, local pickup only
In desperate need of a deep clean and re-dye but could be brought back to presentable shape pretty easily. The drivers lower bolster is deflated but not torn or worn through. The drivers upper bolster was pushed inward and there are some cracks in the drivers front door panel as a result being t-boned (pictured). All door panels need the fabric cleaned and re-glued.
UrQuattro 016 - Make offer, local pickup only.
I was told it has only 63k miles and tend to believe it due to how clean it is externally. It was out of the car when I bought it so I can't speak to its condition conclusively, but it goes into all gears and turns freely by hand. Center diff locker engages by hand as well. Has been drained of fluid.
UrS 01E 5 speed - Free, local pickup only.
~200k miles on it. The drivers side cv cup has pretty nasty radial play due to the cv cup to front diff bearing surface being wallered out. I did drive the car that this came out of around the block at low speeds with no noticeable issues, but I would assume it needs a new diff before being put into service.
UrS4 fenders - $150 for both or $125 for the drivers side / $75 for the passenger side (large dent that has been hammered out but needs paint)
UrS hubs, can turn for small chassis 5 lug swappage if desired - $100 per pair
UrS4 intercooler w/ aluminum end tanks - $50
B3 80 Quattro spoiler - $40
There are a few small nicks and scratches from storage but is generally presentable as is with no distortion in the foam or rust in the substructure.
B4 90 Wing - $40
Originally silver, has been sprayed black. Has scratches and dings from storage. Comes with hardware and gaskets in good shape.
AAN dual mass flywheel and Sachs 240mm clutch and pressure plate - $50
Very usable condition, would have just tossed it but the clutch and pressure plate look like they had been replaced recently
AAN ZF power steering pump - Sold
Very recently referb'd.
Coupe Quattro Speedlines - Sold
Need a cosmetic refresh and the tires are only good for pushing a car around on (literally bought them to push a car on a trailer and back off again). They are straight and come with a spare center cap.
16x7.5 5x112 TSW Imolas - Sold
Cool multi-spoke wheels but they unfortunately dont fit over the brakes on my CQ and the UrQ has gone 5x130 so no reason to hold on to them. Several spare center caps/nuts included.
328mm x 28mm 2 piece front rotors (Stoptech?) - $300
Adapt as you see fit. These have been sitting around for ~6 years so they look a little rough but are next to no miles, rings measure right at 28mm thickness w/ 26mm min (aka new)
Tesla Model S front calipers - $250
Would be great for a monstrous ~355-360mm BBK, pictured next to 997 front calipers and 325mm rotors to accentuate their heft. Super low miles
Supercharged 3.0 and full engine harness out of a B8 S4 with only 8k miles when it was written off - Feeler/make offer. Local pickup only
Bought with the intention of swapping into a small chassis but that would require buying another project car at this point. AC compressor mounts are broken (pictured) and the lower oil pan will need to be replaced. Supercharger had been removed when I got it so it has been replaced with an 80k mile unit.
Colin
 Post subject: Re: Garage Cleanout, B3 Quattro Script, UrQ 016, 3.0T, TSW
PostPosted: Wed Jan 13, 2021 4:43 am
Do you still have those seats available? I am local
PostPosted: Wed Jan 13, 2021 11:23 pm
Yes the B3 interior is still available, shoot me a PM if you'd like to come take a look at them.
Colin
  |  It is currently Tue Jan 26, 2021 2:47 pm
