Post new topic Reply to topic  [ 23 posts ]
V10 Avant
 Post subject: V10 Avant
PostPosted: Wed Nov 18, 2020 4:48 pm
Who would've known the 5.2 would sit right at home in this pig? And with 8" extra between the crank and the front bumper lol. I had to trim the hood to clear the HPFP's, but damn... I'm hoping to have it running by the end of the year.
Pretty simple and basic ~500hp build
-Long Tube Headers
-Intake Spacers
-Ringer Racing Stage 5 Clutch... For all the launches lol
Image20201116_154441 by Joel Francisco
Image20201116_154421 by Joel Francisco
Little Egg Harbor, NJ
 Post subject: Re: V10 Avant
PostPosted: Wed Nov 18, 2020 4:58 pm
Awww hell yeah. Keeping it NA?
PostPosted: Thu Nov 19, 2020 9:49 pm
Definitely keeping this one N/A. Call me crazy, but I prefer the loud, screeching V10. All turbos do is muffle it... plus I'd rather not have to deal with the tuning aspect of a boosted application...
PostPosted: Fri Nov 20, 2020 8:33 am
Very logical! Excited to watch the progress and see it running
PostPosted: Sun Nov 22, 2020 8:57 pm
Engine and transmission came out today, this thing is just caked in grease. Gave it a really good cleaning and will get it back on to start making the exhaust relatively soon. In the meantime, it's time to start cleaning some valves. Here's 1 pass on cylinder #1, already a night and day difference!
Pulled the engine and transmission out today.. In all my time of having the 2.2T, 4.2T, and now this 5.2 in and out of the car, I've never once pulled the transmission. It was absolutely caked in shit! Gave it a thorough cleaning and am fairly happy with the results. I'm moving onto the intake valves in the meantime until my header flanges get here.. Man, these FSI engines are no joke when it comes to carbon buildup. Here's one pass on cylinder #1. I'm guessing I just need to do 2 passes on each and I should be pretty gravy.
Image20201122_155238 by Joel Francisco
Image20201122_162205 by Joel Francisco
Image20201122_215559 by Joel Francisco
Image20201122_202620 by Joel Francisco
Image20201122_204959 by Joel Francisco
PostPosted: Sat Nov 28, 2020 9:51 pm
Got me a Ringer Racing Stage 5 Clutch and Flywheel Kit. 925lbs of capacity on a single disk with a stock B7 RS4 pedal feel and 20lbs steel flywheel for ultimate daily drivability... yet I can really lay into it on the launches and donuts this time. Overkill for sure, but I'm all about that full send life when my cars do run... :woowoo: :woowoo:
Um.. Bolted the clean transmission back up, I have so.. much... tubing... for the long tube headers. Just need to get in my custom cut 3/8" Stainless Flanges. I was contemplating on making a new transmission mount crossover to bolt on the underside and to free up the room where the stock mounts go, buttttttttttt the stock URS can fit a 3" downpipe under the axles so I figured I can too.. Gonna be fun.
Guess that's it for now. ECU's are on their way to get the immobilizers deleted so I can first start it no problems. (Assuming I don't suck (Which I do)).
Here's to the Understeer Gods..
Image20201128_210422 by Joel Francisco
PostPosted: Sun Nov 29, 2020 7:44 pm
thats gonna be a pretty cool sleeper...
nothing. at all. nothing to see. never done nothing and never will do nothing.
just an E-thug bench racer who thinks too highly of himself.
PostPosted: Thu Dec 03, 2020 5:54 pm
A sleeper you say?
I put in a solid 4 hours on it today getting the longtube headers made. It's a shame some 5-1 collectors aren't going to fit between the engine and the front axle. I have to pull cylinder 6 in from the side right at the base of the collector if I have any hope of it working. First thing tomorrow though I need to get the engine in the car to see where cylinder 6 can/can't go due to space constraints on the frame rails and maybe this weekend I'll have them welded.
I know the 4-1 isn't ideal so roast away :lol:
Image20201203_183142 by Joel Francisco
Image20201203_184151 by Joel Francisco, on Flickr
PostPosted: Fri Dec 04, 2020 4:21 am
Given that you needed to clearance the hood to give room for the HPFP, I'm thinking with that R8 intake you'll be needing a HOOD SCOOP!!! Can't wait to see it.
-Jonas
90 CQ (3B, K26/K27 hybrid, VEMS)
07 S8 (Stock)
PostPosted: Sun Dec 06, 2020 3:09 pm
What gearbox do you use? Any adapter needed?
My mate has a VW Passat 32b synchro just standing around and there happens to be an S8 V10 engine as well.
Would make a nice project if the gearbox could be easily solved.
PostPosted: Sun Dec 06, 2020 6:03 pm
I'll hold off on the intake manifold for now. Not too keen on modifying the hood and I'd like to get this setup running first lol.
I'm using the stock 5sp 01e transmission. There's no adapter needed. Just swap in a D3 A8 rear timing cover with a C6 A6 3.2 5mm transmission spacer and it bolts right up to any 01e / 0a3 trans!
Did a test fit and all seems good with room for 1 more on each side! I'll have them welded this week once I get some purging gas and then finish the last runner; hopefully by the weekend.
Image20201206_162750 by Joel Francisco
Image20201206_162650 by Joel Francisco
Image20200713_192326 by Joel Francisco
Image20200713_192312 by Joel Francisco
Image20201206_162905 by Joel Francisco
PostPosted: Wed Dec 09, 2020 8:02 pm
I'll bet it weighs no more than your V8t setup...just a little longer, so it won't affect balance too horribly.
http://coupe.gofergusons.org
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Thu Dec 10, 2020 8:01 pm
I absolutely guarantee it'll be about the same. That schedule 10 piping, turbo, wastegate, intercooler... all very heavy.
This is just an all around better setup in my opinion. I have 8 inches in total for radiator to sit between the bumper and front of the engine. About 3" with the shroud installed which is a shit ton compared to the last one with the radiator, intercooler, and fans.
PostPosted: Sun Dec 13, 2020 12:48 pm
I don't know why I decided to randomly check MG today but I'm glad I did. That V10 coupled with a manual trans should be fantastic. Also, if you listen to exhaust note on some of the C6 S6s...hot damn.
90 CQ
07 FJ
Lots of bikes
PostPosted: Wed Dec 16, 2020 1:54 pm
This is interesting considering the 07k adapter requirements, very awesome!
Ed Hankin *All posts subject to inaccuracy due to multi-tasking and iPhone.
1PissedOff90
If you own a 1990 or 1991 Audi Coupe Quattro and live in North America please add it to the registry! PM or Email me for help, I'm not on MG much ;)
PostPosted: Wed Dec 16, 2020 7:37 pm
The S6's/S8's from the factory are meh. Once these V10's get tube's out the exhaust it changes the entire car! I'm thinking the manual will just add a completely new aspect for it. I was able to weld the primaries up last Wednesday, but kinda ran out of time.. It'll be a few weeks before I make any progress; not that I'm worried about it though.
Image20201215_163604 by Joel Francisco
Image20201215_163624 by Joel Francisco
ImageIMG_2532 by Joel Francisco
PostPosted: Wed Dec 16, 2020 10:06 pm
Congratulations on the little one! Definitely going to be a few weeks until you get back out there, get sleep instead ;)
PostPosted: Thu Dec 17, 2020 4:41 pm
Congrats Joel, I wish my car projects got finished before my kids. My son is turning 14...and my CQ is still not done.
'13 Q7 TDI
'07 Q7 3.6
'90 CQ 32v
'90 CQ 0v
PostPosted: Thu Dec 17, 2020 9:55 pm
Congrats!
1PissedOff90
PostPosted: Mon Dec 21, 2020 11:43 pm
Thanks everybody! Man does time fly; I've had a few nights to get away to the garage while my wife and Lillian visit the in-laws!
Headers fully welded minus the v-bands..
Filled in a bolt hole on the rear timing cover and grinded it down.
Re-sealed the timing covers + rear main seal
Welded on a 1/2" piece of aluminum to the transmission that'll be drilled + tapped to accept the crank sensor and mounting bracket
Installed the Ringer Racing Stage 5 Clutch Kit
Assembled engine + transmission
Headers are going on as soon as these V-bands are done!
But don't take my word for it!
ImageIMG_20201220_151002_209 by Joel Francisco
Image20201221_193158 by Joel Francisco
ImageIMG_20201221_211224_019 by Joel Francisco
ImageIMG_20201221_210156_088 by Joel Francisco
ImageIMG_20201221_214340_958 by Joel Francisco
Image20201221_231259 by Joel Francisco
Image20201221_233625 by Joel Francisco
Image20201222_004208 by Joel Francisco
Image20201221_173407 by Joel Francisco
PostPosted: Sun Dec 27, 2020 7:39 pm
Finished the headers up earlier last week...
I ordered some C4 4.2 tie rods as they have a bend in them to clear the heads and water pipe crossover tube.
Engines ready to go in
Image2020-12-27_09-22-00 by Joel Francisco
PostPosted: Sun Jan 10, 2021 12:29 am
So, been a minute but quite a bit of progress...
Engine made it's way into the car.
Made a dual 3" exhaust to single 4" axle back
Wired it all up (I've since then gone through the harness and got rid of all the wires I didn't need... it was a lot)
Just waiting on a new crank sensor and I'll go ahead and fire it up. In the meantime I'm knocking out the last little bit. Mounting and plumbing the radiator/coolant lines. After that, it's driving and tuning time.
Image20201230_195200 by Joel Francisco
Image20210105_205203 by Joel Francisco
Image20210105_205215 by Joel Francisco
Image20210104_150852 by Joel Francisco
Image20210101_172747 by Joel Francisco
Image2021-01-10_02-24-22 by Joel Francisco
Image20210108_230729 by Joel Francisco
Image20210108_230931 by Joel Francisco
Image20210108_230946 by Joel Francisco
Image20210108_231321 by Joel Francisco
Image2021-01-10_02-28-20 by Joel Francisco
Image2021-01-10_02-28-47 by Joel Francisco
PostPosted: Sun Jan 10, 2021 4:04 pm
good progress, few people at the point of firing up v10 conversions.
Where did you get the wheels from? genuine porsche splits?
  |  It is currently Sat Jan 23, 2021 9:20 am
