Author |
Message |
RennenMsports
Post subject: ISO: front and rear calipers and brackets Posted: Wed Dec 23, 2020 1:31 pm |
kickin' tires'n lightin fires |
Joined: Tue Nov 22, 2005 1:11 pm Posts: 857 Location: South Florida
Doing a 5 bolt swap and have urs front hubs at all 4 corners.
_________________ Lite some tires and start some fires
91' 80q
Top |
varia
Post subject: Re: ISO: front and rear calipers and brackets Posted: Wed Dec 23, 2020 8:35 pm |
I post, therefore I am |
Joined: Thu Mar 12, 2009 10:42 pm Posts: 4044 Location: Lost Angels, Ca
RennenMsports wrote: Doing a 5 bolt swap and have urs front hubs at all 4 corners. on what car ?
_________________ ¯\_(ツ)_/¯
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Thu Dec 24, 2020 7:19 am |
Oops. 91’ 80q. With a 6mm spacer Attachment:
91' 80q
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Thu Dec 24, 2020 9:28 am |
varia wrote: im not sure if i understand how did you install urs4/6 hub on the rear of a B3 80q
Isnt those are 82mm instead of the 75? I must use wheel bearing 33412220987 from a bmw e36. And machine the hubs to roughly 42.2 mm according to the guy I got the shafts from
91' 80q
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Thu Dec 24, 2020 10:54 am |
I would like to use urs front and rear brakes but either way they have to fit behind these wheels. The guy said something about using c5 s6 269mm and/or c5 A6 4.2l 269mm rotors but I’m not sure exactly. Attachment:
91' 80q
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Thu Dec 24, 2020 1:08 pm |
Ok thanx. Over complicating things keeps my brain entertained. Cars bring me peace of mind and the ability to stay out of trouble. I also tend to over engineer things. I’m sorry if I frustrate you or anything else for that matter. You help me a lot with information to help build my beloved Audi and I really appreciate you a lot!
91' 80q
Top |
varia
Post subject: Re: ISO: front and rear calipers and brackets Posted: Thu Dec 24, 2020 4:40 pm |
my recipe on the rear was for this 90, its has a two pieces suspension, it was a 20V car originally: B5 A4q rear hub (New bearing, 75mm) B5 S4 rear disk B5 S4 rear brake caliper bracket D2 S8 rear brake caliper, cos its aluminum (urs4/6, v8 rear can be used as well) (I even used a front forged control arm on the rear) Attachment:
If your 80 had a 1 piece upright, i would upgrade that first.
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Thu Dec 24, 2020 7:31 pm |
It actually came with 2 piece uprights and I just got 2 piece 82mm knuckles. Will the B5 A4q rear hub accept a front B5 S4 outer cv joint?
91' 80q
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Thu Dec 24, 2020 10:03 pm |
The 75mm rear gets the BMW bearing with a 6mm spacer and a urs front hub machined down to about 42.2mm Attachment:
91' 80q
Top |
varia
Post subject: Re: ISO: front and rear calipers and brackets Posted: Thu Dec 24, 2020 11:20 pm |
RennenMsports wrote: The 75mm rear gets the BMW bearing with a 6mm spacer and a urs front hub machined down to about 42.2mm Attachment: DE0D4C90-A682-4FCF-BB14-053E34163608.png got it. now the interesting part will be to find a caliper bracket, and disk that will fit because the diff. hubs (4-5mm)
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Fri Dec 25, 2020 7:46 am |
He stated If I use urs6 rear brakes I can use a c5 s6/c5 A6 4.2l 269mm rotor Attachment:
91' 80q
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Fri Dec 25, 2020 9:48 am |
Will a rear urs caliper bracket bolt onto the rear of a B3? Merry Christmas by the way!
91' 80q
Top |
varia
Post subject: Re: ISO: front and rear calipers and brackets Posted: Fri Dec 25, 2020 10:04 am |
RennenMsports wrote: Will a rear urs caliper bracket bolt onto the rear of a B3? Merry Christmas by the way! Alone it might, but the offset of the ur4 hub and/or disk will make it hard to use Merry Christmas to you too.
Top |
RennenMsports
Post subject: Re: ISO: front and rear calipers and brackets Posted: Sat Dec 26, 2020 3:41 pm |
varia wrote: RennenMsports wrote: Will a rear urs caliper bracket bolt onto the rear of a B3? Merry Christmas by the way! Alone it might, but the offset of the ur4 hub and/or disk will make it hard to use Merry Christmas to you too. Ok. Thank u for your input! I appreciate it!
91' 80q
Top |
james12lucy
Post subject: Re: ISO: front and rear calipers and brackets Posted: Wed Dec 30, 2020 6:42 pm |
Stuck in first |
I have a set of URS6 front and rear drilled rotors and a set of rear calipers available.
Top |
