motorgeek.com :: Board index :: The Tech Lounge :: Gas and Sparks
Help with ignition coil ID
 Post subject: Help with ignition coil ID
PostPosted: Mon May 10, 2021 12:37 pm
I bought a (now vintage) 034/ Pantera Efi standalone setup years ago, and am now installing it, however I ran into a small roadblock. The setup came with only 4 ignition coils (I thought there were 5) and running the P/N comes up with a coil for a 10VT/ 3B, however the coil is very obviously different. Can anyone ID the application for this coil? I'm thinking maybe V8? Thanks for your help! Image
Sent from my SM-G973U1 using Tapatalk
 Post subject: Re: Help with ignition coil ID
PostPosted: Mon May 10, 2021 2:09 pm
I'm pretty sure the 10vt coil is different from the 3B and that that's a 3B coil
The 10vt are this style with ring terminals:
https://www.autohausaz.com/pn/13591565- ... GZEALw_wcB
The 3B have a 2 pin plug on bottom and a mounting flange like the one you posted a pic of:
https://www.ebay.com/itm/Original-Genui ... 3945389477
-Shawn C.
2002 B6 A4 3.0l->1.8t+Southbend+VEMS+Rods+HX35=happy daily
1987 5ktq most reliable $500 I've ever spent
1989 200tq Avant- Gone but not forgotten
1986 GTI- longterm project
And one brindle pup in the back
PostPosted: Mon May 10, 2021 4:10 pm
Thanks Shawn, good call. You are spot on. Thanks. I figured the 10v and 3B's were the same, but they are indeed different as you noted.
  |  It is currently Mon Jun 14, 2021 6:39 pm
