motorgeek.com :: Board index :: The Tech Lounge :: Abnormally aspirated
my boost/afr gauge setup
 Post subject: my boost/afr gauge setup
PostPosted: Tue Jun 01, 2021 6:02 am
Thought id post my new boost/afr gauge since im pretty pleased with how it turned out.  I used a plunge router/jig to cut out a clean hole in the little door that covered the coin holder, then hid the internals in the pocket behind it.  Its probably more work then a round gauge in a vent hole, but i've never loved that look for some reason..
This is the gauge here: http://www.veisystems.com/ws/custom-instrumentation/48-open-frame-dual-function-gauge.html
There's a fair amount you can configure the output, and it has a peak boost & afr recall function that is pretty handy..
and you'll need a wide band controller to go with it, i used an AEM one that came with a bosch wb sensor.
Now I feel a lot better about trying out the mtm chipped ecu I've had sitting around for years...
Sent from my SM-G960U using Tapatalk
04 s60 R
16 Golf Sportwagen- sold
 Post subject: Re: my boost/afr gauge setup
PostPosted: Tue Jun 01, 2021 6:51 am
Looks good!
PostPosted: Tue Jun 01, 2021 10:52 am
Right on! Nice work!
1990 Audi CQ
2003 Audi S8
PostPosted: Thu Jun 03, 2021 12:28 pm
clean af! awesome work
  |  It is currently Mon Jun 14, 2021 6:02 pm
