2nd speed rad fan always runs and relays clicks repeatedly
 Post subject: 2nd speed rad fan always runs and relays clicks repeatedly
PostPosted: Sat Jul 03, 2021 7:00 pm
So my radiator fan started constantly running with the key in the on position and/or with the car actually running, even when the car is started from completely cold. At the same time the 2nd speed fan relay (#2 in the main fuse panel) constantly clicks repeatedly pretty fast, about twice a second.   I tried unplugging the radiator temp switch, the after temp sensor, and what i think is the pressure switch for the AC (which doesnt work btw, and the belt is removed) and none of them change anything.  and I tried swapping out that relay with 2 different spares that both do the same thing..
So what are the other triggers for that relay and/or the fan? I cant make sense of the wiring diagrams.. Any other thoughts?! thanks a lot
Sent from my SM-G960U using Tapatalk
04 s60 R
16 Golf Sportwagen- sold
 Post subject: Re: 2nd speed rad fan always runs and relays clicks repeated
PostPosted: Sun Jul 04, 2021 7:16 am
Is the climate control on or off when you turn the key on? Try unplugging the afterrun temp sensor on the water manifold.
PostPosted: Sun Jul 04, 2021 12:07 pm
I thought the climate control didn't effect it, but i just went out and played with it some more and it will remain the same in all the cc modes except defrost, when i hit that button it stops, and stays off as far i can tell, until you change to any other setting, weird.. gremlins in cc ctrl unit..? but feel like im missing something else
04 s60 R
PostPosted: Sun Jul 04, 2021 12:19 pm
It should run with the CC on every setting but ECON. Only exception is in very cold weather.
  |  It is currently Sat Jul 24, 2021 4:47 pm
