motorgeek.com :: Board index :: The Tech Lounge :: Suspension
5 lug conversion - worth it?
 Post subject: 5 lug conversion - worth it?
PostPosted: Thu Jul 08, 2021 8:25 am
Hi all. So my '91 90 is in need of some new wheels.. or potentially lots of things. The 4 lug 17x8.5" wheels I bought it with are way too fat for the fenders and are causing tire rub on even moderate bumps. They've gotta go. Trying to decide between a quick and easy 4 lug replacement, or if it's a good time to think about converting to 5 lug.
I know lots of you guys have done it. Thoughts on if it's worth it, or if I should be looking at upgrading to B4 fenders... etc etc?
Current Car:
'91 90 Quattro (AAN Swap)
Past Cars:
'90 Audi 80 Quattro
'92 Audi 80 Quattro
 Post subject: Re: 5 lug conversion - worth it?
PostPosted: Thu Jul 08, 2021 1:51 pm
obviously the 5x112 wheel selection is much bigger then the 4x108, so yes.
you will need new bearings, maybe brakes (depends on the hub you will use)
PostPosted: Thu Jul 08, 2021 5:55 pm
Got it. Wasn't sure if it required new bearings but I guess you break them to get the hub.
Any idea of cost of parts? The brakes are from a B4 90 (same as an Audi 200 I believe), so they are a little bigger. Will need new rotors for the 5 lug.. but I think the calipers should fit?
Current Car:
Past Cars:
'90 Audi 80 Quattro
'92 Audi 80 Quattro
PostPosted: Thu Jul 08, 2021 8:17 pm
caliper: 200 had a few g57 (maybe?), ufo, and G60, just like the B4 90 (same as the CQ).
As for the disk: you can re-drill yours, or use something else, but it all depends on the 5x112 hub that you will use.
  |  It is currently Sat Jul 24, 2021 3:46 pm
