Post new topic Reply to topic  [ 5 posts ]
5ktq Only runs with fuel relay Being jumped
 Post subject: 5ktq Only runs with fuel relay Being jumped
PostPosted: Mon Jun 01, 2020 2:56 pm
Is this going to be a fuel pump issue?
 Post subject: Re: 5ktq Only runs with fuel relay Being jumped
PostPosted: Mon Jun 01, 2020 5:31 pm
does the tachometer work? definitely not a fuel pump issue, more like something that is supposed to be triggering the FP relay is not triggering it.
Dana
-4kq efi'd 10vt
-1990 90q 20vt: 3b swap
-1990 90q 20vt: 11.7 @124.5
PostPosted: Mon Jun 01, 2020 5:36 pm
Yes the tachometer works fine
PostPosted: Tue Jun 02, 2020 8:38 am
Could it be the reference sensor??
PostPosted: Tue Jun 02, 2020 6:30 pm
My guess would be the relay itself, I don't actually think there's anything that would keep that relay from turning on but also let the car run.
To verify just put a multimeter and put it between 85/86 pins with 30/87 jumpered and the car running you should see 12v across 85/86, if you do it's the relay, if you don't it's either the ECU's fuel control circuit or a break in the 30 wire.
Double check your fuses, but again I think if you had a blown fuse the car wouldn't run at all.
-Shawn C.
2002 B6 A4 3.0l->1.8t+Southbend+VEMS+Rods+HX35=happy daily
1987 5ktq most reliable $500 I've ever spent
1989 200tq Avant- Gone but not forgotten
1986 GTI- longterm project
And one brindle pup in the back
Users browsing this forum: Google [Bot] and 1 guest
  |  It is currently Sun Aug 09, 2020 12:43 am
