Post new topic Reply to topic  [ 6 posts ]
5ktq update
 Post subject: 5ktq update
PostPosted: Sat Jun 27, 2020 7:23 pm
Hey guys at 3000rpm and above my engine light comes on and after driving for 10 mins down and shifting My engine will sputter the tachometer goes crazy the oil light comes on then my engine will die could this be a fuel pump related issue? Maybe a speed sensor? The knock sensor perhaps??... injector seals maybe??
 Post subject: Re: 5ktq update
PostPosted: Sun Jun 28, 2020 2:20 pm
I'd check for codes and the crank sensors
Sent from my SM-A102U using Tapatalk
1994 s4: O1E 6spd swap, Stromung 3" turbo back,and so on
1983 Audi 4ks Plain Jane
1990 90q 20v: Project?
1990 90q 20v: Parted out/ junked RIP
1982 Honda v45
X2 1995 S6 part cars
PostPosted: Sun Jun 28, 2020 3:23 pm
Could be a lot of things. Seems like your are struggling with this car. I would suggest finding a local to you knowledgeable audi enthusiast to come help you with it.
90 90Q 20v 91 200 20v avant 92 urS4 03 S6 avant
PostPosted: Mon Aug 03, 2020 5:25 pm
Any guesses why my car won’t rev past 3000rpm while driving?? But in neutral it will rev to redline... no check engine light on after 3000rom anymore. I found a few vacuum lines not connected which seemed to help a lot but I can’t get past 3k rpm (while driving). The gas in my car is over a year old could that be the a suspect? It backfires kinda bad but I didn’t want to fill up in case it’s a fuel pump issue. I put a fuel system cleaner in the tank, any other recommendations??
Thanks!
PostPosted: Mon Aug 03, 2020 9:37 pm
Welcome to CIS ownership. Replace all vacuum lines, check for cracks in all rubber air connectors/hoses, and replace the injector seals.
Sent from my Pixel 4 XL using Tapatalk
-Alex- @vexartmedia on Instagram
1992 Porsche 968 (07K transplant in progress)
1983 Aud UrQ (MC1, GT2871R, IIc)
2003 Audi S8 (DD)
Past Audis: 87 CGT, 87 4kcsq, 93 S4, 90 CQ, 87 5ktq, 95.5 S6Avant, 86 CGT CE, 95 90qs 1.8T, 83 UrQ, 87 CGT 7A
Past P-cars: 80 931, 87 924S, 87 951
PostPosted: Wed Aug 05, 2020 8:24 am
Lots of good info here already. Pull codes as that will help diagnose. SJM's site is invaluable when owning one of these cars.
1986 4kq CE
1991 200 20v wagon
Users browsing this forum: No registered users and 5 guests
  |  It is currently Sun Aug 09, 2020 1:14 am
