Rota Custom 4x108 17x8 Wheels, BELIEVE
17K views 69 replies 29 participants last post by  40v4kq
#1 ·
Well...its finally happened! :eek:
034Motorsport has Rota 17x8 wheels IN STOCK, yes, in the flesh! We had these special made for us by Rota, these aren't available anywhere else.
We needed a bunch of wheels for the shop, so we just made some and ordered extra.
Here are the specs:
-Rota Slipstream style
-17" x 8" wide, 35mm offset, 4 x 108mm (yea, you read right)
-Drilled for m14 studs or bolts
-20 pounds weight
-Available in Flat Black or Hyper Black (Hyper black is like a "black
chrome", a very shiny reflective black, looks silver from some angles, looks black from others).
-$195 per wheel, in stock.
Pictures below are of Hyper Black color:
And a picture of Flat Black
I haven't listed these on the site yet, I'll give Motorgeekers a shot at them first.
Thanks guys, and if you have any interest email me at javad@034motorsport.com
Thanks,[/img]
#28 ·
We have a couple sets here, we can get more whenever you need.
#32 ·
dom said:
So if I were to want a set around summer time you guys would be able to get them even if you didn't have any in stock?
I believe they have to be ordered in sets of 5 (20 wheels), so you should probably get them while they have em.
Frank the quattro tank said:
How well would these fit under a 90q fender? Would they stick out a bit?
I don't they will fit. You need a CQ or B4 90 (flared fenders).
#36 ·
245's should clear fine, depends on th brand though. The tie-rod is the tricky bit, and why we rotate the arms for the bigger tires.
#37 ·
Yep, I may have to look into doing that.
My 22545R17s are getting old and worn (Been rotating them in since 05; Summers only). Rather then buy new 225s I may try and UPGRADE!
#43 ·
Correct, we did a custom run of 20 wheels. What is available now are the 'normal' Rota offerings. No where near enough interest to keep up runs of custom wheels for these.
#45 ·
sayoda said:
Makes sense! Would 225 be a good tire size for the 7.5?
Works fine on a 17x7. I suggest looking at the manufactures suggestion on rim width.
#51 ·
Ziptied said:
Oh god, why of all rota knockoffs would you want to have the spoon replica.... eww.
got another you recommend?
