61 - 80 of 563 Posts
Discussion starter · #62 ·
ShavedQuattro said:
Nice Martin! The car is looking like it is coming together! Looks like another monster urq in the making. I will be interested in to how you deal with the 01e linkage.
I think I've chosen the Ur-s4/016 path. I don't have any 01Es at the moments (all sold) and still waiting for the three to arrive from Europe so it might be a while till I have something to work with.
Then the driveshaft puzzle will commence as well.
Cheers
Cheers
Can't wait. :D I like puzzles!!
Nice Martin.
Gotta say I was wondering how you were living with no urq. Must have been daily misery for you :)
Looking forward to seeing it on the road - here and hopefully in person one of these days/months/years.
ralleyquattro said:
white 83UrQ said:
Looks like a vacuum brake setup?
Yes, I thought about keeping the hydraulic, but for simplicity sake I chose the vacuum.. plus I had all the parts handy.
If anyone needs any hydraulic parts I have like two or three complete systems now.. ;)
Looks great Martin!!!!
I'm really glad you went with the vacuum brakes.....much cleaner IMO, and less weight.
I can't wait to see this thing running.
Brilliant project.
Cheers,
Craig
So how different are the MTM and the Wagner IM?
I'd consider using one of them on my build, currently have all the RS2 IM, fuel rail, pressure pipe, ect!
What radiator you planning on using, or going to angle a stock sized one to clear the AAN oil pan?
Jack
Discussion starter · #70 ·
So... tried to get the intercooler in... looks like I either have to move the motor back at least a 1/4" and move the motor mount down 1/2" or just get a smaller intercooler (the easy way out). I am still refusing to cut any of the original sheetmetal!
So, pics... here it's looking good.
Not so good here, actually touching the cover.
And no way to get the snub nose stopper in.
I also do not have a proper pulley, but it looks like it might just clear.
hank, you have the same size and yet you somehow got yours in.
This IC is 28x9x2.5
I wish there was a 28x8x2.5 but the only size smaller is 28x7x2.5.
Comments, suggestions are welcome
Discussion starter · #71 ·
Jack
Hi Jack,
I don't have a Wagner so can't comment on side by side.
ABY/ADU fuel rail fits the MTM no problem, 3B might but I haven't tied one yet.
I'll be using 034 alloy rad with RS2 shroud and 5kt fan.
The engine has 3B/7A oil pan so no need to tilt the rad.
HTH
is that at the stock length Martin, or is it at the 01e length without a 15mm spacer? Why not ditch the spacer and get a free 5/8"?
That looks a lot like my IC, but the updated bar and plate design. I wish I was working with a serp setup like you are though. I may bite the bullet soon and re-balance the assembly with the AAN setup. Why is the 9" too tall? Does it hit the crank pulley?
Discussion starter · #74 ·
Transmission is not there yet, this is at the limit of the engine mounts, I might elongate them a bit at least 1/4".
My clutch setup is for non spacer application, so none will be in place once the tranny slipps in there (I hope).
I've decided that I'll lower the snub nose a bit which means custom design.. it will look like the sport one that's made of steel plate and a pipe. I'll try to find a pic of it.
Like Craig said, the IC will be toughest part of this project. Wish I had a tig welder and knew how to use it.. ;)
I'm not positive on all this, but..I'm sure I'll get corrected if I'm posting inaccurately.
With using a AAN serp belt system, I'm assuming you are planning on keeping the AAN hydraulic pump and bracket because they are such a good design together. But, doesn't it have quite a bit more pressure that your rack might handle? A friend placed a 3B pump and bracket in his UrQ and it blew the seals out of the UrQ rack. Can you step down the pressure, back to the UrQ pressure necessary? The 034 short ratio rack is capable of the higher pressure, as would be any CQ rack, I believe the CQ 7A Hyd pump is about the same pressure as the AAN.
Are you keeping A/C via the AAN pump?
Jack
Martin, this might be dumb question, but without the trans there do you have something in place holding the motor from tilting forward right now? maybe that's where your 1/4" will come, at least up top where the TB cover is.
